Page 29 of 30 FirstFirst ... 192021222324252627282930 LastLast
Results 281 to 290 of 291
Thread: power supplies with minimal radio interferance?
  1. #281
    Feb 2011
    Yeah right, your sarcasm at the end clearly shows that...
    And I meant it. If I hurt you in some way, which your reply suggested, I am truly sorry!
  2. #282
    Mar 2011
    Quote Originally Posted by Carlo201983 View Post
    What do you think of the graphite spray?
    Mickz ??
  3. #283
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Hi Carlo, I've never used it but graphite would likely be resistive and therefore unsuitable of this application.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  4. #284
    Mar 2011
    Quote Originally Posted by Mickz View Post
    Hi Mickz,
    ok then do the wooden box and do within a cage of steel sheet 0.5 obviously all connected to ground. but if after all this rigmarole still not solve. I do? abandon this project? may find useful the hardware I used in car PC?
  5. #285
    Sep 2009
    Australia
    Hi Mickz,
    You really don't have to do this if the PC works with no interference when connected a standard mains ATX power supply.
    The M4 in that small enclosure you made should be as noise free as a standard mains powered supply. The top and bottom lids may be causing a problem.
    BTW Aluminium not steel.
  6. #286
    Mar 2011
    I'm sorry but the houses of the PC are not made of steel sheet? the allumimio and I was told that in rf fencing little. I repeat once again the m4 fed alone (without a computer) drive does not generate any problem.
    EDIT:
    I found out where the problem lies. Pratically LCD on, disconnecting the VGA cable from the MB the problem disappears. MickZ you think the problem is in the LCD or VGA onboard the MB. ?
  7. #287
    Mar 2011
    ok guys since there is no solution. finally abandoned the car PC. return to the stability of the double din. at least there although there are limitations it all works without interference. thank you all. hello
  8. #288
    Feb 2014
    Another possible feed thru cap?
    On the subject of pass thru caps how would this one be
    http://www.digikey.com/product-detai...166-ND/2079740
    No funky soldering or need for the double sided circuit board
  9. #289
    Feb 2014
    Will this capacitor be better and easier to use?
    Wondering if this capacitor would be easier to use.
    Digi-Key Part Number 410-1166-ND
  10. #290
    Sep 2009
    Australia
    EDIT: I found out where the problem lies. Pratically LCD on, disconnecting the VGA cable from the MB the problem disappears. MickZ you think the problem is in the LCD or VGA onboard the MB. ?
    I did not see the edit you made and since you have gone back to a standard DIN solution it's not much use answering but.
    It's not uncommon for the VGA cable, LCD or even refresh rate or screen resolution (set in windows) to cause a problem in some installations. I found some cause a problem if the refresh rate is above 59Hz or 60Hz.
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 03:01 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  3. Joining 2 power supplies ??
    By vicky_obee in forum Power Supplies
    Last Post: 05-18-2006, 07:03 AM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  5. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 07:39 PM
