Update:
So I visited my friend who was having the static problem, this time he really had tried a desktop PSU and found that he could get reception (don't ask). Sorry for not believing the PSU was causing it. He also had another M2-ATX that we did some
testing with.
1) With only the M2-ATX powered up, a little bit of static, reception got worse but was still getting stations.
2) Loading down the power supply by actually powering up the PC, reception completely killed. Makes sense, whatever is happening occurs as the supply is forced to create more power.
Now we had verified that the M2-ATX infact creates interference in the FM
radio band. But, why?
My car also has same tuner and M2-ATX although my M2-ATX is older by about 2 years.
So the only two different factors are
1) Older vs newer M2-ATX
2) My car has external antenna, his has an in the window glass antenna (amplified).
He did not have a good external antenna to try, so we could not rule that out. But I did wonder about the M2-ATX versions. Digging up the changelog:
I figured that since my power supply works fine, there must be a filtering issue and low and behold cap changes and oscillating problems are noted. I looked at his power supplies, both were missing cap C15, mine has Cap C15. It is located nearby the 4 pin 12V connector. Interesting.
I'm contacting the company who makes these PSU's to see if I can get more info from them.
