Page 5 of 27 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 266
Thread: power supplies with minimal radio interferance?
  1. #41
    Jul 2009
    And another one with reception issues....
    Am I correct in stating that the general concensus is that it's the M2atx is THE issue?
    If so, what would be the best replacement?
    And if I would have to replace my M2atx, would there still be a possibility to switch my PC on/off based on ignition status?
  2. #42
    Mar 2008
    Boston
    Quote Originally Posted by kove View Post
    You are going to get 100 people swear by Opus. I am considering trying one.
  3. #43
    Jan 2008
    i would recomend the opus, or the dsatx, i personaly use the dsatx, and can't say i am having any, or have heard of any with interferance issues with them
  4. #44
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Add me to the list.
    I tried to get some help and offered some of my troubleshooting exercises in the Road Runner forum...
    http://www.mp3car.com/vbulletin/road...ml#post1334775
    And here is another thread where someone was having the same trouble...
    Shielded antenna cable?
    But THIS thread looks like the place to be. I'll post my continued troubleshooting here and watch with great interest the rest of yours.
    Thanks....
    Mark
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
  5. #45
    Jul 2009
    I did the test... using the Directed unit without switching on the pc. Result, excellent reception, great quality sound, RDS working flawless. Even without an amplified antenna, reception is still perfect. I have also noticed that my (company) laptop does not cause any interference! Can even put my laptop against the Directed unit and it still works!!
    Guess my only option now is to find me a new PSU......
    Any suggestions?
    Thanks...
  6. #46
    Dec 2007
    Quote Originally Posted by nrgizerbunny View Post
    i've just done some back to back testing with a M2atx and an opus 120w. The difference between them is huge! I originally thought my HQCT was rubbish so I got a radio from Mitch js, turns out there was nothing wrong with the hqct it was just the interference generated by the M2-atx.
    Looks like the Opus is the other choice. Which $uck$, since I designed my entire system around the specific components I had.
  7. #47
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I sent an email to ituner networks/mini-box regarding this issue and got a confirmation they received my mail but no further response even after I checked with them few weeks later. This was on 4/27 and again 5/8.
    I believe it is a combination of both radio antenna type (amplified) and PSU. Simple solution is a different brand of PSU unless ituner wants to redesign/fix their PSU.
  8. #48
    Low Bitrate mrheat's Avatar
    Jun 2005
    Lower Bavaria/Germany
    hi all
    i have an m4-atx with same problems...
    tried nearly everything...if car pc is on, FM radio is impossible in a range of about 1,5m around the PSU.
    last week i tried to rf shield the entire psu, see pic. Helped absolutely nothing.
    When carPC is supplied via normal ATX AC/DC PSU i can hear radio fine.
    see my carputer here: click
  9. #49
    Jul 2009
    just bought the OPUS DCX3 online. will let you know if this works and doesn't interfere with my fm band like my M2atx
  10. #50
    Dec 2007
    I'm ready to spring for one, too. Problem is it looks like the one available on mp3car.com does NOT have the 4-pin plug for a P4 style mobo. The only place I've seen one that does is direct from Opus for $120.
    Let us know if the Opus cures the problem. I'd feel a little better about the $120 if I KNEW it was the cure.
    Thanks...
    Mark
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 03:01 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  3. Joining 2 power supplies ??
    By vicky_obee in forum Power Supplies
    Last Post: 05-18-2006, 07:03 AM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  5. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 07:39 PM
