Page 8 of 30 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 291
Thread: power supplies with minimal radio interferance?
  1. #71
    Aug 2009
    mstaedt, glad you are making some progress on your truck.
    This is a very helpful thread and giving me a lot of idea for when I re-wire the Tahoe. Actually, we want to shave the factory mast antenna off, does anyone have any good directions they can point me in for a good replacement?
  2. #72
    Mar 2009
    I also have this issue, using an m2-atx with a window antenna. I have an idea, and won't mention it until I try it because it will not please anyone unless it works, but it has to do with the grounding points.
  3. #73
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Quote Originally Posted by mazda8 View Post
    Why don't you tell us what your idea is anyway. Then if it doesn't work, the rest of us won't waste our time going down the same path.
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
  4. #74
    Dec 2007
    Quote Originally Posted by mstaedt View Post
    Next step will be to reconnect the ignition wire back to the original wiring harness. This will leave only the +12V battery wire and ground wire to the computer laying across the seats.
    Ran into a little trouble here. The wiring harness that includes my ignition wire also includes the wire from the PSU to turn on the amps and also my 12V rail out and 5V rail out wires. I plugged all that in at once and reception was back in the toilet. So I split up the connector and started plugging stuff back in 1 wire at a time. I got as far as the ignition wire in and amp wire out with no issues. I also plugged the 12V rail out wire back in, but it isn't actually powering anything right now because I still have the HD tuner running off the battery on the floor.
    Next step is to plug the HD tuner back into the truck wiring. That will energize the 12V rail out wire.
    Progress may be slow for a while. One of my two test stations (88.5 HD-3) seems to be having issues with their transmitter and they've been broadcasting only analog since yesterday.
    And an unrelated problem - either my M2-ATX or my mobo is starting to act up. Sometimes I need to whack the case once to get the PC to start booting up. I may end up switching back to the Opus sooner than planned.
  5. #75
    Elsewhere
    I've recently taken interest in this thread.
    While at first I thought it would confirm my suspicions abount the quality of mini-box's products, it doesn't appear that is the case.
    Earlier in the thread, someone mentioned a faraday cage, as well as enclosing the PC itself in wire mesh.
    All good ideas, I think.
    Another idea is to shield cables in something like TechFlex Flexo Conductive.
    (Well, I think it's a good idea, anyway...)
    CN is braided from 11 mil carbonized NylonŽ monofilagoodment yarn. CN is designed to protect sensitive wiring from abrasion while shielding it from high frequency noise. Many successful applications have utilized CN for maintaining clean video signals, interference filtering in pro sound environments, and RF filtering on power cables and outputs. CN is also useful in static sensitive environments.
    CN utilizes a patented carbonization process which infuses our braided sleeving with a microscopic carbon compound that is virtually indistinguishable from the base material. The result is a strong, long lasting jacket that is ready for the most sensitive applications.
    Admittedly, that could possibly be marketing hype. I have seen TechFlex's products and they are quality. This might be worth looking into to shield cables.
    There are sizes that could be used for the signal cables, power cables, etc.
    If it works for your radio interference problem, it can also be put on to have a very clean look.
    Just a thought.
    How about the Wiki?
  6. #76
    Dec 2007
    Quote Originally Posted by DarquePervert View Post
    hmmmmm.
    I wonder if the stainless steel type typically used to dress up hoses in engine compartments may also work.
  7. #77
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    The funny thing about that techflex is that COAX cable already has a shielding cable just like that built in and without it any signal down that wire would really suck. in CATV world, your reception would go down the toilet if this would be broken in any place along the cable. I guess you could double shield it, make sure it is terminated to ground at one end so the noise if any is grounded and has some place to go.
    I am curious about the moving of grounding point idea and the re-routing of certain wires idea. Keep up the troubleshooting and there might be a good explanantion sooner or later.
  8. #78
    Dec 2007
    Thumbs up back on track
    88.5 is back on the air digital, and I solved my problem with the computer cutting out.
    Now...where was I?
  9. #79
    Dec 2007
    I gave it a break over the weekend.
    Hopefully I can get back after it this week
  10. #80
    Dec 2007
    Back at it.
    I plugged the Visteon back into the original under-carpet wiring harness. The ferrite ring is still installed. All OK
    I plugged the main power wires to the computer back into the truck harness, but still had the ignition input wire running off the battery-on-the-floor. Still OK
    Ran a wire straight from the fuse panel to the ignition input on the PC. I took this intermediate step because I think a big part of the problem is coming from the fact that ALL the wires to and from the PC are bundled together. It seems that the ignition in, amp out, 12V rail out, and 5V rail out wires are particularly unhappy about that. So I'm moving REALLY slowly with these. Still OK
    I've now completely weaned the system from the battery-on-the-floor without any major change in performance, so I took a big step this morning and plugged the monitor back in and also re-installed the wifi antenna. One of those did have a minor negative effect on reception. It's still decent, but my favorite (weak) station cut out a couple of times for a few seconds on the way to work.
    I could live with it like it is, but I still have to plug the amps back into the M2-ATX and run the 12V and 5V rail wiring back to their components.
    I ran across some shielded wire at work yesterday. I may experiment with that some...
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 04:01 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Joining 2 power supplies ??
    By vicky_obee in forum Power Supplies
    Last Post: 05-18-2006, 08:03 AM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 08:39 PM
