Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Still confused on DC/DC, Shutdown controllers, and STR... couple Qs please.
  1. #11
    Jan 2003
    Ruston, LA
    For the OPUS:
    Pay attention to Q 3 & 5
    DC-DC ATX Vehicle Power Supplies Frequently Asked Questions.
    In this section we try to address the commonly asked questions associated with our range of
    DC-DC Vehicle Power Supplies. If you do not find the answer to your question in this list then please contact us here so we can address your enquiries in person.
    Q. What are the dimensions of the SFX-12-15 power supply without the enclosure?
    A. The barebone board is 37mm (1.45") high, 123mm (4.85") long and 96mm (3.75") wide.
    Q. Why is a Opus Solutions, Inc. DC-DC supply better than an inverter and AC-DC power supply?
    A. Opus Solutions, Inc. DC-DC supplies are over 90% efficient. Using an AC inverter paired with a regular PSU to power your vehicle based computer system can be as low as 50% efficient - placing extra load on your car's electrical system. Inverters can also create a lot of electrical 'noise' which can seriously effect the performance of your equipment.
    Q. How does the shut-down controller work?
    A. The shut-down controller is controlled by monitoring the switched 12V line. When power is cut from the switched line (turning off your ignition) the shutdown controller sends an ATX pulse to the operating system to initiate your chosen shutdown mode(shutdown, hibernate, standby).
    Q. Can I alter the amount of time the supply waits before initiating a shutdown command?
    A. Yes. The delay between cutting the switched power and the ATX pulse being sent can be set to 10 seconds, 20 minutes, 40 minutes or 60 minutes using jumpers on the powerboard (factory default is set to 10 seconds).
    Q. I want to use the hibernate option which requires a small amount of power, can I do this?
    A. Yes. Because the DC-DC unit draws it's main power directly from the car battery, it still maintains the standby power requireb bya computer in hibernation mode.
    Q. Will the supply protect my battery from being drained when the computer is running?
    A. Yes. The Opus Solutions Inc. DC-DC power supplies have a built in low voltage sensor that will shutdown the computer to protect the life of your battery, should it get too low (depending on battery condition).
    Q. Car batteries can have power spikes, is my Opus Solutions, Inc. DC-DC supply protected from this?
    A. Yes. All Opus Solutions, Inc. DC-DC power supplies have built-in over-voltage protection and carry an onboard ATO (automotive blade fuse) to protect both the power supply and the computer connected to it.
    Q. Will my computer reboot when I start the car (because of the drop in voltage)?
    A. No. Because of the advanced circuit design built into every Opus Solutions, Inc. DC-DC supply your computer will continue to work for up to 10 seconds of continuous engine 'cranking'.
    Q. Do Opus Solutions, Inc. Supplies come with a warranty?
    A. Yes. All Opus Solutions, Inc. DC-DC power supplies come with a 3 year limited warranty. For more warranty information click here.
  2. #12
    Nov 2002
    Holland, MI
    Sweet exactly what I wanted to hear thanks... and about the SCSI burner... I just want a burner period, its going to be in my un-used din slot hidden because my screen will be folded out in front of it 90% of the time... I make cds for friends a lot and I never end up remembering when they want one so I figure if I have a few blanks in the glove box I can knock off a cd in a parking lot or when we drive somewhere in 6 minutes and be done with it (also makes it easier to show them all my music on the spot without needing some huge list printed out).. I wont here "is my cd done yet" plus that should pay for gas easily... my car eats up like $10-$20/day in the summer because I like driving it...
    Mainly just for convenience of making mix cds since my friends ask quite often and I like to be nice and help out... plus id like a cdrom drive period, its only a few watts more for a burner
    I think I decided on the Opus 150watt PSU w/ built in controller btw... looks sweet and I calculated everything im using in my pc on a power consumption calc and it still has about 30 watts to spare.
    1993 Toyota Supra Twin Turbo (Silver)
    1994 Toyota Supra Twin Turbo (Black)
    SupraPC is currently in the works
    http://www.pooshda.com
    http://version6.pooshda.com
  3. #13
    Jan 2003
    Ruston, LA
    Ok that's cool. The burner thing.
    And on your wattage requirements, you probably have more headroom than that, cause that's if your using max power on everuthing at the same time
  4. #14
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    just thought I would say... nice car. I have one... torn apart...in the garage... for about a year now . I can't wait to get it driveable again. The urge to just install a PC in it now is overwhelming... but a garage PC (as in essence it would be) isn't too appealing to me right now
  5. #15
    Jan 2003
    Ruston, LA
    Well you wanted a "secure" car didn't you ? Sorry couldn't resist
  6. #16
    Jun 2002
    Norway
    Be nice
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
  7. #17
    Jan 2003
    Ruston, LA
    Originally posted by t0ffluss
    Be nice
    I'm sorry, was innapropriate. ddt is cool anyway
  8. #18
    Jun 2002
    Norway
    Albert Einstein
  9. #19
    Nov 2002
    Holland, MI
    Thanks... mine hasnt been started in a while, also torn apart.. im currently trying to cover the rest of the costs for a Single turbo upgrade... I made a new years resolution of hitting 10s before 2k4... so I better get my *** in gear
