If the PC is shutting down and starting up properly when you throw the valet switch, then I would grab your multimeter and check the voltage on the ACC line controlling the P1900.
Check the voltage with the ignition on and (more importantly) when the ignition is off.
Make sure you check the voltage on that line for enough time after the ignition shuts off. IT almost sounds like the ignition line is "bouncing" and power is being restored to it shortly before the P1900 does its cutoff.
There could also be a problem w/ the P1900, too. It may need a firmware update.
LinkBack URL
About LinkBacks
