Results 1 to 10 of 13
Thread: DSATX 3 blinks?
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    DSATX 3 blinks?
    i set my dsatx to keep the 5vsb on so that i could do standby. when acc goes low, the computer goes into standby like it should but when i look at the dsatx it's showing me 3 blinks every few seconds. in the user manual for 3 blinks it says n/a. is this the expected behavior of the dsatx in sleep mode with the 5vsb still hot?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by kuo View Post
    If i'm not mistaken, 3 blinks means its in hibernation mode. In that case it would be normal. Correct me if i'm wrong though..
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    So i discovered that not only is the 5v still hot, the 12v is also still on because if i manually hit the power button, the computer will turn on even though acc is low. I don't think it's working correctly. Anyone have any ideas?
    Apr 2001
    Portland OR
    We have an update for this that we are testing. It is version 115 and it will hibernate more solidly..
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    can't say enough good things about jeff and the dsatx. the support he has provided has been great. from researching on the forum it doesn't appear that too many people use s3 standby with the dsatx since there are less than 10 threads about the topic. most here would recommend s4 hibernate over s3 standby to prevent degradation of your battery but that's a different topic.
    in getting my new install up and running, i discovered a quirk with the dsatx when enable5vsboff is set to 0. because of some hardware driver issues my computer would randomly decide to hang when going into standby. in firmware 114 the dsatx would wait patiently for the computer to go into standby and would only kill power once the battery voltage dropped below the lowvolts threshold. there was at least one occasion when i left my car for a few hours only to come back to discover that xp had hung going into standby and had been drawing full power the whole time i was gone. when brought to jeff's attention he modified the code for me and sent me firmware 115. here's how it works. if enable5vsboff = 0, when acc goes low, the dsatx will send a pulse to the power button and the computer will begin to go into standby. if for some reason after 90 seconds the computer has not yet gone into standby, the dsatx will go ahead and pull the plug and go into deep sleep.
    i have since figured out my hardware/driver issue but it's great to know that when i leave my car, if the computer does not go into standby correctly, the dsatx will pull the plug on the misbehaving machine. one side effect of this modification is that in 114 you could manually power up the computer even if ACC was low. it is convenient to be able to power up the computer without a key in the ignition but having a failsafe is much more important to me. in 115 if the system is in standby drawing only from +5vsb and the dsatx is in hibernate mode and you try to manually power up the computer, the dsatx will see the power on signal and treat it like the computer got hung up and pull the plug and go into deep sleep mode. as jeff mentioned in his email, this is actually a good behavior for those using standby and who don't have a master kill switch and want a quick way to put the dsatx into deep sleep for times when they know they won't be driving the car for a few days.
    the new firmware does exactly what i need. big thanks to jeff for his great support and for a great product.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Thank you for this great post!!! I have the 115 firmware too, and saw these 3 blinks. A little search and I got the above explanation.
    Just to make sure, you left enablesleepon=1, right? So that it can go to deep sleep.
    I have just left enable5vsboff=0, so that the 5v allows sleep mode. So this should be good.
    Thanks a lot!
    Boy, love this forum! Repped!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    how are you guys updating your firm ware? I was under the impression that the brainstem is required for that and that most people have problems with the brainstem. Do i need to send it to jeff to have it updated?
    Live mp3Car Facebook Chat
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    ripplinghurst, i have enablesleepon=1 and enable5vsboff=0 and it leaves my carputer in s3 standby.
    sonicxtacy02, i also have trouble with the brainstem causing the dsatx to behave abnormally. i have the usb version so what i was able to do is use my laptop to load firmware and change settings on the dsatx. i was never able to use the carputer connected to the dsatx with the brainstem to change settings or monitor the dsatx.
    on a different but related topic, with hybrid sleep and windows 7, i think it would be the perfect setup to have the dsatx keep my carputer to in s3 standby for 3 days before going into deep sleep and pull the plug on the 5vsb and go into deep sleep if any longer than 3 days, and next time i drive the car it comes out of hibernate instead. i'm thinking could accomplish this by bumping up the dsatx's lowvolts value up from the default 11V to high 11's or low 12's but i'm not that clear on what value i should use and how much time it would give me in standby. maybe someone with a little more knowledge about voltage, amps and what not can chime in here.
    Woodbridge, VA
    Blog Entries
    32
    thanks for the info.. i'll have to try that.
    Dec 2007
    Danville, CA
    Quote Originally Posted by Sonicxtacy02 View Post
    I'm using a very old pentium III laptop, that I take it to the car and plug the brainstem to it's external good old COM port. It's very reliable that way. I can never connect it to my carputer, it won't work properly.
    I know that somebody posted on the dsatx forum that he connects the DSATX to the Carputer bypassing the Brainstem altogether via a "phone data cable", which I believe it's one of those COM-TO-USB motorola or whatever cell phone cables? I wonder what the brainstem is supposed to do anyway.
    The post if from a guy called Marcel, and I wonder if it's the same MarcelIP from CF forums and here? I forgot to post more info about it.
  1. Problem with new DSATX
    By jbradshw in forum Power Supplies
    Last Post: 03-31-2008, 06:59 AM
  2. DSATX 5 blinks.....
    By thefreeauction in forum Power Supplies
    Last Post: 03-24-2008, 05:27 PM
  3. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  4. Does your DSATX shut down after 5 blinks?
    By Will Albers in forum Power Supplies
    Last Post: 08-16-2007, 01:24 AM
  5. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
