Results 1 to 10 of 15
Thread: Getting total power requirements
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I'm trying to revamp my install a bit because I'd REALLY like to use an Opus PSU because of all of it's intergrated circuitry. I'm trying to figure out power requirements for a Celeron-based system and this is what I've come up with so far.
    Asus CUV4X-C 30W 3.3V and 5V
    Celeron 1GHz 30W 5V
    TV Tuner 7W 5V
    Lucent PCI Adapter+WiFi Card10W 5V
    Geoforce 4 64MB 30W 3.3V
    512 MB PC133 RAM 40W 3.3V
    Maxtor 80GB 10W 5V and 12V
    Slim DVD ROM 10W 5V and 12V
    Deluo USB GPS ??? ???
    Touch Controller (USB) ??? ???
    LCD Controllers (2) ??? ???
    IRMAN ??? ???
    Help me out here, does anyone have a guess about the power requirements of the last 4 components?
    Also when I'm converting watts to amps, for use in an automobile, should I use 12V or 14.4V???
    Sep 2002
    Redmond, WA
    Not sure how you came up with all of those numbers.
    You should be measuring how many Amps each devices uses and at what voltage.
    Most devices will list their power requirements. Harddrives, cdroms, dvd's, etc should show on the label.
    Lets say I have two components:
    my DVD drive requires:
    12v 0.8A
    5v 1A
    My laptop harddrive requires:
    5v 1A
    Now add it up. Let's start with 12v:
    Dvd(0.8A) + Harddrive (0A) = 0.8A
    Now 5v:
    Dvd(1A) + Harddrive (1A) = 2A.
    So the power supply must supply at least:
    12V .8A
    5V 2A
    The wattage is more of a generalization on power supplies since it lumps all of the different voltages together.
    to find Watts, you multiple Current(Amps) times Voltage.
    so 12v * .8A = 9.6W
    5v * 2A = 10A
    for a total power consumption of 19.6W
    If the device doesn't list it, then you can just measure it with an Ammeter. Most meters will measure Amperage up to 10A.
    You simply put the meter in-line with the device. Power up the computer and watch the needle to find the peak.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Online guide to power requirements for PC Components.
    Look at my question at the end. I realize that Amps = Watts / Volts. I need to know if I should use 12V or 14.4V in the calculation. Then and only then would I be able to get an accurate representation of what I need.
    I have not purchased the components yet. I would like to know if it works prior to purchasing them. Saves money!
    I have two components.
    12v 0.8A
    5v 1A
    5v 1A
    Now 5v:
    12V .8A
    5V 2A
    so 12v * .8A = 9.6W
    5v * 2A = 10A
    Once again I realize exactly just how the math portion works and I know the specs of most components AND the PSU. My questions were:
    AND
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Anything usb cant greater than 500ma x 5vdc, and id guess the irman uses next to nothing. The lcd controllers im not sure about, but I know the specs for my 5" ntsc lcd + backlight + inverter + controller say its less than 750ma@12vdc. hth.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Sep 2002
    Redmond, WA
    If you are trying to convert the Wattage listed for each component back to how many amps, to match up with the OPUS, then you divide the list watts by the device voltage. Has nothing to do with being in a car, or 12v or 14v.
    no way to calc this without knowing how many watts for each voltage.
    Celeron 1GHz 30W 5V
    this requires 6A at 5V.
    TV Tuner 7W 5V
    1.4A at 5V
    (this seems high)
    2A at 5V
    9.1A at 3.3V
    12A at 3.3V
    (this seems high to me)
    Can't calc.
    Can't calc
    Sep 2002
    Redmond, WA
    Google is your friend:
    From
    http://www.pocketaprs.com/gps.html
    Deluo/EverMore GM-305
    Power requirements. Rated voltage is 3.8 to 8 VDC; current, by measured testing, 140 mA during acquisition, 125 mA with satellite lock (manufacturer rating is 105 mA). This GPS comes configured to mooch power from the PS/2 (keyboard) port of a laptop PC. Variable voltage testing revealed that internal regulation was linear, so I would not recommend connecting this GPS to straight 13.8V mobile power (lest it go "poof!").
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    okay gotcha. THAT was screwing me up.
    Celeron 1GHz 30W 5V
    TV Tuner 7W 5V
    1.4A at 5V
    (this seems high)
    2A at 5V
    9.1A at 3.3V
    12A at 3.3V
    The site I looked @ quoted 10W per 128MB.. now it might be for newer faster DDR RAM. I dunno.
    Can't calc.
    Can't calc
    Thanks for doing the math for me makes my slightly intoxicated life easier!
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I'm unaware that the Opus has a 3.8 to 8V DC line. Google isn't my friend it seems...
    I'll go with MP3DUB's answer, being that the GPS was of the USB flavor and doesn't get power off of the PS2.
    and just a little FYI... I'm the LAST person you need to tell to search.
    Sep 2002
    Redmond, WA
    the device itself probably needs 5v
    Jan 2002
    Chicagoland, IL
    Also, im sure you have your reasons, but isnt 512 a bit much for a carpc? And doing a bit of googling, it seems that pc133 has a maximum power draw of 10w per module, with average consumption being lower.
    -Nick
