Results 1 to 4 of 4
Thread: which of these is the best way to power both my amp and my PC
    Mar 2009
    these are the only 2 ways i can think of so which of these is better and are they any other better ideas any of you have please let me know
    thanks
    D
    or
    FLAC WuNgUn's Avatar
    Sep 2007
    Ditch the relay...don't need it...
    Connect the PSU and amp remote on directly to the ACC line in the ignition key...
    Do NOT tap into the headunit for remote on for the PSU especially! The amp is okay there though...
    Or you could even use one of the outs on the PSU to turn on your amp, depending on which PSU your using..."Anti-Thump".
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    What PSU have you got?
    On my M2-ATX I have remote output, but it comes on allmost immidiately as my soundcard will give bump when initialized by PC half a minute later.
    You can try and find a soundcard that doesn't do this, or delay the signal. Best is probably something that can be enabled by PC when it is done booting.
    Mar 2009
    well tight now i have the M2 but it only has 2 powewr wires and the shutdown and I made the startup/shutdown controller. and the pc is hooked to the headunit. already have too many wires running so i thought that will be easier to use a relay
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. My PC plans - anything wrong with this system?
    By mx270a in forum General Hardware Discussion
    Last Post: 09-02-2003, 07:32 PM
  3. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
  4. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  5. Here's an alternative power source....
    By A Boy and his Miata in forum General Hardware Discussion
    Last Post: 11-21-2000, 12:44 PM
