Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: please some help on finished sproggy
  1. #11
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    ok after 4h this night and 2h today i figured out this:
    - sproggy connected to mobo-
    - pin 14 connected to groud via little wire
    - the i give the mobo the pwr good - it starts
    no way to start it with the switch
    Any idea - last night i was not far away of trowing it out of the window or making it a AT PSU - I'm totally about it - until today cost me about 80EURO
    Anyone wth a little idea please please please
    EDIT
    my voltages are the following - could someone please compare .
    A=4.3V
    B=PSU ON 3.7V ;PSU OFF 4.48 V
    C=PSU ON 10.54V PSU OFF 13,28 V
    D=4.95V
    So what is the problem with my PSU?
    Felix
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
  2. #12
    FLAC Mastero's Avatar
    Aug 2001
    India
    your voltages seems fine ... if your psu kicks on the mobo when you connect the pin 14 to ground then i feel your mobo is not giving ground through pin 14 use a ac psu and check if the mobo is giving ground on pin 14 and does the ground hold there..
    your PSU is working perfectly as designed the 4.46 v on the stby is not a problem....
    when your pin14 (gren wire) is given ground (not frm the mobo seperate ) does the sproggy kicks on and boots the mobo ?
    Cheers
    Mastero
  3. #13
    Apr 2002
    Europe
    the mobo works ultra fine with an AC psu
    via MObo Pin 14 seems not to bee grounded- only voltage drop i think-
    when i ground pin 14 manually the PSU (relais) turns on and mobo starts fine .
    EDIT
    with an AC PSU its perfectly grounded
    with the sproggy I have the following voltages
    : B=PSU ON 3.7V ;PSU OFF 4.48 V
    point B = green wire
    /EDIT
  4. #14
    Aug 2001
    India
    ok felix your having a very weird problem ... you can replace the 2n3094 and see if solves your problem.
    Mastero
  5. #15
    Apr 2002
    Europe
    hi maestro , is it a simple NPN transistor or does it do somethong specific (caracteristiques) because cannot find it /and store also on those Transistor equivalent books
    Tnx
    felix
  6. #16
    Aug 2001
    India
    hey sorry its 2n3904 simple npn
  7. #17
    Apr 2002
    Europe
    does not work now i'm not far away of throwing the whole thing out of the window . - No with the new transistor it even doesn hold anymore when i bridge 14 w. gnd after i putted the old transistor in - the same no more hold.
    so the ultime chance is that those 4.4V Stndy are not enough . but how to change this because the diode cut 0.6V
    so I'have 3 solutions left :
    1) you or someone else got a good solution trick for me
    2) the sproggy will go AT version
    3) i'll desolder all and build PT cruisers version
    so at this point i dont know what is wrong - perhaps if you could give me some mesurement point to check and some reference voltages of a working sproggy - perhaps it could help finding out
    thanks
    felix
  8. #18
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    Mastero, I need your help man, I have biult a sproggy and it wont work with an EPIA M 6000. It simply refuses to POST. All voltages are good, no matter what delay I put on the pwr good signal, it refuses to boot. Ive checke and double checked and checked again about a dozen times everything, even tried different brands of inductors, changed the lm2587-12T and all the diodes, still no good. using the push button on the EPIA the sproggy (ive modified it to power up the relay with a 5v relay and 7805 for the purple +5sb supply) and the fan on the EPIA starts up, everything looks really good, just no boot HDD spins up, starts doing it checks, looks really good. NO POST!.
    Whats your suggestion?
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
