Results 1 to 10 of 18
Thread: please some help on finished sproggy
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    [subject changed] sproggy wont boot my Mobo pse help
    hi,
    today after getting a fine heatsink - my sproggy 2.8+ is now 100% finished but not working
    all output voltages except 5VStb ( purple wire ) are 0V
    All is connected after the shematic i got from maestro
    I think its coming from the relais :
    the relais is not clicking , and I have no ground on on of the pins so that might be the problem -
    here are some pics of mine perhaps you find a mistake
    I build it after this shematic :
    http://www.automp3.de/dev/2.8.jpg (340K image)
    My sproggy in unfinished stadium:
    here are some pics of the sproggy
    big images to see better
    http://www.automp3.de/dev/sproggy.html
    thanks much for any help !
    felix
    BTW : what voltage do i put on remote line ??
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    Apr 2002
    Europe
    so here another pic wth explanations on it - so there must be somethiong wrong with relais layout ?? please look at the last link on my previous post to see if i did something wrong
    Many
    Felix
    Apr 2002
    Europe
    OK i got it with the relais (stupid me ) but my mainboard doesnt wanna boot will see tomorrow,all voltages are ok but ...... mainbord refuses booting
    bye
    felix
    Apr 2002
    Europe
    i folowed a trick to put a big C between 5V and GND but still mobo refuses booting.
    I tested 3 Mobo's but no success -
    please anyone with an idea ????!!!!!
    :cry:
    FLAC Mastero's Avatar
    Aug 2001
    India
    ok buddy let me see .. do these check before i answer you ques..
    a) connect both main and remote to positive and ground to ground
    b) check if your getting the 5vstby from the 78L05
    c) connect ground to pin 14 and see if the relay click (if it does then check the volts on the PSu ..
    Let me know ..
    Mastero
    Apr 2002
    Europe
    hi maestro
    a) done
    b) done I got 4.5V ,
    when PSU is on I get
    12V is 12,22V
    3.3V is 3.3V
    5V is 5.05V
    and 5V on grey wire
    all neg Voltages are also correct
    some one on Divx-car told me to try the following
    put a big C ~1000uF between GND and 5V .
    ( i made a picture to show better)
    c) works relais clicks and psu is on
    when PSU is off ( relais not clicked) i get 4.42V between green wire and GND. 4.63 V between purple and GND.
    could this low "5V" from the 78l05 be the cause ?
    thanks
    felix
    Aug 2001
    India
    ok till now everything is fine ....
    Your sproggy is working perfectly fine... dont put the big caps... !
    now check the following...
    a) The pins on the ATX power connector is wired correctly... double check it ....
    b) Check the power good delay .... if its giving proper dealy use a multi meter....
    Let me know..
    Mastero
    Apr 2002
    Europe
    ok for the cap - the guy told me that on his sproggy that worked so i tried
    I toked a ATX connector from a broken PSU of a friend of mine - not the cables /connectors which where in your semi kit i bought.
    so i think all is correct.
    for the delay what should it be ? how to measure it ?
    thanks
    Felix
    Aug 2001
    India
    use two multimeter and check the +12 and after how long the power good kicks in ..
    If possible change the chip 4049..
    Mastero
    Apr 2002
    Europe
    a bit hard to mesure - but 5V kicks in ~1sec later than 12V
    BTW are the ~4.6V for 5 V stndby ok ?
