Results 1 to 2 of 2
Thread: Opus Xformer - Max Load
    Feb 2003
    SE Ohio
    Let's say I decide to go with an Opus DC-DC Transformer like this one http://www.opussolutions.com/150watt.html
    How much stuff could I hook up to it before I'd overload it?
    I'm planning on around 1GHZ AMD, a 5200rpm HDD, DVD_CD-RW, a PCI soundcard, a 4 USB port PCI card, and the PCI card that runs my LCD Panel. I also plan on putting in a USB IR Remote reciever, a USB Cam, and a USB GPS system, along with finally, a USB Cirque Cruise Cat touchpad.
    That's a CPU, HDD, DVD, 3 PCI Card's, and LCD that pulls 10W, 4 USB devices, and a PS-2 mouse.
    Can it handle it all?
    I'm guessing the wattage used up by the USB devices is small, but I don't wanna toast the Xformer.
    I coudl always run 2 Xformers parallel but then again for 300 bucks, I could have that Sine-Wave generated UPS & an el cheapo 400W Inverter.
    What do you guys think the best bet is?
    If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    1985 Supra 7M-GTE
    10.4" Planar LCD
    ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
    Edimax EW7318USG Wifi w/ 7 db Ant.
    USB GPS
    Jan 2003
    Ruston, LA
    you should be fine, and I don't think it would fry it anyway, it just would either shut down or your system would crash alot
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
