Results 1 to 9 of 9
Thread: How long will battery last with M2 on P1?
    Dec 2006
    Quick question: if I set my M2-ATX to P1 (5s + 1 min. autolatch / 1 min. hard off), so that it's only drawing .5 ma, approximately how long can I leave the car off without draining the battery?
    Portecho: Entertainment Technology News, Reviews and How-to's
    Elsewhere
    There's no way to answer that without knowing about your battery, the specs of your PC and your audio system.
    How about the Wiki?
    Dec 2006
    Well, I was just looking for a ballpark answer... and why would any of that matter, beyond the specs of the battery? Both the audio and the pc would be off, save the .5 mA mentioned that the m2-atx supposedly draws when completely off.
    fwiw, the audio system is stock Honda Odyssey, nothing fancy (no amp) and the pc is based on the Intel D945GCLF (built in Atom) + 3.5 IDE HD + one or two usb peripherals.
    Elsewhere
    Sorry. Misread your post.
    How about the Wiki?
    Dec 2006
    OK, perhaps I should phrase the question another way...
    For you guys using a m2-atx, have you ever returned to your vehicle and found your battery dead (assuming proper wiring and proper hibernation)? If so, how many days had transpired?
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Hum.. It realy depens on the battery of you car and the car itself.
    a 50a/h battery can deliver 50ampere for 1 hour!
    a 70a/h battery can deliver 70ampere for 1 hour... and so forth.
    0.5ma is 0,0005a
    So, if 0.5ma is the ONLY thing the battery need to keep alive, it will do so for 100.000 hours (if a 50a/h battery).
    But keep in mind, every car now days, have memory and other things drawing tiny bits of ampere all all times.
    Sep 2008
    Joliet
    My Altima has sat for days with the PC off with no problems . Even in the dead of last winter it was OK .
    Just be absolutely positive the PC shuts down . I 'thought' my PC shut down
    ok but it either locked up or rebooted itself 'cause in the morrning I had a very dead car .
    Now I enable hibernation just in case I 'forget' to shut off the PC.
    Dec 2006
    Thanks for the feedback, guys. That pretty much provides the answers I needed.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    i have a good old fashioned switch inline on the power cable, even tho i have a "smart" psu with all the bits, cant beat a switch for knowing that its all off
  1. What kind of cap/amp?
    By asong31 in forum Car Audio
    Last Post: 12-26-2006, 02:30 PM
  2. How long can you run a 90W power supply off the battery?
    By Pseudo Nim in forum Power Supplies
    Last Post: 06-24-2005, 02:27 AM
  3. How long will it take for my battery to run out?
    By Deep in forum Power Supplies
    Last Post: 05-06-2005, 07:34 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Programming Question in VB
    By az1324 in forum Software & Software Development
    Last Post: 10-01-2004, 10:24 PM
