check out the user guide: http://www.opussolutions.com/pdfs/DC...ck%20Guide.pdf
assuming from you description that this is the PSU you have you should be able to change JU1 jumper to lower the start-up voltage to as low as 10.5v. if that doesn't help then you have another problem.
LinkBack URL
About LinkBacks
I'm having the same issue. Cheers, mate!
glad you got it working. Yeah wire is weird that way. It confused me at first too.
