Results 1 to 10 of 17
Thread: Pico power supply question
    Apr 2005
    So for the time being my power supply is fried and I'm looking for an inexpensive replacment until I can afford something really nice. I was looking at the pico ones, but noticed they have a dc 2.5mm jack. I looked on line for more pics and ebay I noticed it plug into a power brick and into the wall 120v.
    Can I wire this directly into my car and bypass the power brick?
    Any other cheap solutions?
    Mar 2009
    near Rochester, NY
    Most of those require regulated 12V input, they do not regulate the 12V on the PSU. The M3-ATX does regulate the 12V and can be used as-is in the car.
    Apr 2005
    The m3 is $80. Can't I use something less expensive for temp use?
    I have a dsx12vd which is brand new, however my motherboard the epia-m10000 (something something something) doesn't use the 4 pin input. Unless there is a way to change that.
    Mar 2009
    near Rochester, NY
    Sounds like you could connect the car to the dsx12vd, then the output of that to one of the Pico-PSUs.
    Apr 2005
    Can I do that? That would be great! The dsx12vd only has the 4pin wire though and the pico psu has the 20 or 24pin.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    No, from the sound of it, you plug the pico psu into the mb and use the dsx to supply the needed 12V to the pico psu.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Mar 2009
    near Rochester, NY
    As far as I can tell, yes, you can do that. You would need to hack up the 4-pin cable (or get another to hack up) and get a connector for the DC-in on the Pico-PSU, connect the positive wires from the 4-pin to the positive on the DC-in and ground to ground, and connect your car to the dsx12VD.
    Apr 2005
    I can see how that would work. Yellow is 12v anyway and the picopsu takes 12v input. Now I just gotta find one. I want it like yesterday lol
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Looking at the 12vd it appears there is a .25inch spade connector that also outputs 12v. That can carry more current.
    Plug the pico psu into the m10000 and supply the pico with power from the 12vd to regulate the supply.
    Want to:
    Apr 2005
    Thanks bug, I'll go that route then, but where do you see a spade connector?
    http://images.google.com/imgres?imgu...a%3DN%26um%3D1
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Power Supply Quick Question
    By redcell3 in forum Power Supplies
    Last Post: 05-22-2008, 12:51 AM
  3. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  4. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 01:38 PM
  5. Power Supply Cable Question
    By meissenation in forum Power Supplies
    Last Post: 06-25-2006, 10:20 PM
