Results 1 to 7 of 7
Thread: Hmm, won't power up. Driving me CRAZY
    Apr 2005
    So I have a via-m10000 motherboard. My opus power supply went dead so I had a dsx12vd sitting around and I ordered a picopsu
    This one to be exact
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=400025648028
    Right now I have the pico plugged into the MB. THe white wire going to the spade connector on the dsx12vd. The ground is going to the same ground as the dsx12vd. THe powers are jumpered together to make things simpler as it's on my bench.
    The red light is on on the dsx12vd. When I hit the power button on the MB, as soon as I let it go the LED on the dsx12vd goes off and the fan on the MB spins for about 1 second, then stops.
    I first hooked them up about 1 hour ago and it booted a few times no problem but now it won't. The fuse is good. I have it plugged into a battery charger set to 12v on 6amps. I tried it at 2amps and still get nothing.
    At one point the fan on the MB would not turn on at all, it would just twitch. Like it started to spin like a 1/4 rotation and stop then just twitch.
    Also the 4pin connector on the pico I tried connecting that to the dsx12vd and tried leaving it disconnected which is the state it is in now. I figred if I had a p4 board it would just jumper from the 20pin to the 4pin on the board and since I don't have that I don't need it.
    Help me because I"m lost and I would love to get it working by this weekend.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Try the MB with a known good desktop Power Supply to prove the board is working.
    TruckinMP3
    Read the FAQ!
    Apr 2005
    Yep it works fine that way.
    Apr 2005
    Also I took the dsx12vd out of the configuration and it still did the same thing.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by MAZDABOY View Post
    Power the PICO from the known good power supply to eliminate it as the weak link.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Apr 2005
    It's off the battery charger which is good since I used it to charge my battery recently.
    Apr 2005
    Does the ground on the pico power supply go to the ground 4pin connector coming off the dsx12vd or does it go to chassis ground?
  1. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  2. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Sound playback issue driving me crazy.
    By Arby in forum General Hardware Discussion
    Last Post: 05-09-2004, 09:35 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
