Results 1 to 9 of 9
Thread: how does M2-ATX turn off my pc???
    Mar 2009
    I feel very stupid - but I've just bought one and this question came into my head....
    When I turn my ignition off, how does the M2 tell my PC to shutdown/hibernate?
    as far as I can see - the only connection to the mobo from the M2 are the power cables themselves
    now for power up I have my bios set to auto power on when power is detected.........or does the M2 do something fancy here too?
    cheers for the help guys
    Lewis
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by lewisdg View Post
    Lewis
    If the only connection to the mobo is the power cables themselves (20pin ATX and optionally 4pin P4 connector) then you installed it wrong and the M2 is doing nothing but essentially pulling the plug from the wall.
    You need a cable from J8 to your mobo's ACPI Power Connector.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2009
    2k1T....I've only just ordered it, it will be here tomorrow.
    thanks for the reply..........whats an ACPI power connector???
    google here I come
    I'm moving from a laptop setup where by I turn it on via a pushbutton on the dash.....thats why I may sound abit slow - sorry
    Vendor - Qube colin's Avatar
    Dec 2006
    The ACPI power button is that button on the dash that you're pushing. The button that tells your motherboard to turn on/off regardless of whether or not it has power. That's why when your computer is plugged in at home, it isnt ALWAYS on, you can shut it off and turn it back on later without cutting the power completely.
    Mar 2009
    ah ok.....so where currently I have a 'push' button on the front of my desktop....that leads to port/plug on the mobo.....?
    the M2 will connect there instead and act as the push button to power on and off the pc??
    have I got that right?
    Dec 2006
    Yep.
    Mar 2006
    And optionally you can connect that pushbutton to the M2, since it is in parallel. So you can do it manually or have the M2 do it automatically.
    Mar 2009
    heheheheh, how often do you talk about that j8 pin eh ,2k1Toaster??
    Mar 2006
    Quote Originally Posted by Enraiha View Post
    I'm thinking of getting a tattoo.
