I don't post much here but I am constantly reading through the forum and with all the information here, I have been able to get my MacMini (running vista) with
Carnetix p1900 working wonderfully (
YouTube video of my setup).
I would like to make some changes in my setup to bring the MacMini back home from the car. I have purchased an Intel D945GCLF2 motherboard to replace it and will be using a 200GB Sata drive and 2gb Ram.
My Current Setup:
Carnetix p1900 + 5v
Lilliput 7in LCD (Carnetix Powered - Secondary Output)
Slim DVD Drive (Carnetix Powered - 5v Add On)
Macmini (Carnetix Powered - Primary Output)
Bluetooth Dongle (MacMini Powered)
USB to Serial (MacMini Powered) For HD
Radio
USB Touch (MacMini Powered) For Lilliput
USB HUB - 4Port (Carnetix Powered - Carnetix Powered - 5v Add On) does NOT draw
power from MacMini (lead was cut in hub)
BU-353 (USB Hub Powered)
FusionBrain (USB Hub Powered)
External USB port (USB Powered) For iPod or iPhone connection
Here is my question:
To adapt my current p1900 to my new Intel D945GCLF2 motherboard I have purchased a picoPSU 120 WI 25 Wide Input PSU which allows its to be powered by regulated voltage range from 12v to 25v (Carnetix will be setup to send 18v regulated). I plan to remove the USB Hub from my setup and plug all use devices direct into the motherboard. Will the p1900 combined with picoPSU 120 be able to power all usb devices and motherboard safely? Without draining my battery too fast?
Also I am thinking of using S3 standby. Will I benefit from this? Will the USB devices still have while in S3 Standby?
