Results 1 to 3 of 3
Thread: Power supply - electrical expertise needed
    Nov 2008
    Hi all, been a long time since I've visited these forums.
    I finally decided to get this laptop into my car, and bought an official compaq car DC-DC adaptor. However, it is the wrong connection for my laptop, so i decided to see if I could merge the existing power supply adaptor to the new in car power supply.
    I hacked apart the cables and found that my laptop runs off three wires, one at 18.5V the other at 14V and the other a ground, whereas the new supply has simply 18.5V and ground (both are rated at 65W/3.5A).
    I am thinking of making a voltage divider (two resistors in series). Firstly I want to know if anyone knows the what the current will be at both pins (my fuse has blown on my multimeter), and secondly how I would control the current through the voltage divider, or will it just draw the current it needs?
    My electronics is mega rusty so any help would be greatly appriciated.
    Regards
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    have you tried to just connecting the 18.5v and ground wires and leaving the other wire disconnected?
    Nov 2008
    Yeh thanks I tried that with the original power supply but it does need it.
    I should have updated this sooner, I bought an inverter instead, seemed the simplest way to do it besides it was only £20 from maplin.
    Next problem im facing is trying to get an aux input on my blaupunkt headunit, I don't want to take it out but all the methods I have tried have failed
    Thanks for the reply though!
  1. Replies: 5
    Last Post: 08-21-2007, 01:20 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  4. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
