You can connect it to the PC's power supply.
Yea I have an FM Modulator and i wanted to know how do i hook up the + and - wires to get power into the car i dont know where to connect those 2 wires can someone help me please thanx
PC audio --->FM modulator~~~~~~Car radio ---->speakers.
TruckinMP3
Read the FAQ!
but the thing is i cant hook up modulator because I dont have my stock radio anymore i replaced it with an indash LCD from www.digitalww.com
OK, then why were you asking how to hookit up if you are not going to have a headunit in the car?Originally posted by Maddog
if you still need (in your mind) to use an FM modulator.... maybecause you have one, The first step will be to instal a headunit
have fun
TruckinMP3
Read the FAQ!
you have plenty of options
-power supply of pc. since it does do 12+
-car cigarrette lighter another 12+
-or any place on the car such as HU wire, fuses, steering column bolts, ..i can keep going.
the only problem with pc power supply is the fm modulator is only on when the pc is on. But I suppose if you are using the modulator to get sound for your pc, then this is fine.
other options, the problem is if you accidentally leave it on when you turn your ignition off, then you can sap the battery. Ofcouse oyu can use a ignition live only source. But the problem with this is now you can only get sound when the ignition is ON. =)..
I would saw connect to thte pc.
Mine needs to be updated.
