Results 1 to 9 of 9
Thread: Additional M2-ATX plug
    Constant Bitrate soyfish's Avatar
    Mar 2008
    Canberra, Australia
    Hi Guys,
    I'm looking to make an AC power hook up for my carputer, I"ve got some software issues that are going to take longer to sort out than my battery will allow. I've made the hackup ATX PSU mentioned elsewhere in the forums, but I just need an additional plug to solder into it, so I dont' have to cut out the one that is wired into the car.
    The plug I'm referring to is the one that has a number of wires in it, but mainly the pos neg and ign wires that goes into the back of this unit (shown in the top left of this pic:
    Does anyone know if there is somewhere I can get another male plug for this?
    Cheers.
    Elsewhere
    Check a local electronics shop, not the local Best Buy or other shop that sells TVs, computers, stereos and consumper electronic devices. You need a place that sells electronic components.
    Mouser, Digikey, Maplin are online shops that would likely have what you want, as well.
    How about the Wiki?
    Mar 2009
    near Rochester, NY
    This the right thing? http://store.mo-co-so.com/6-pin-16aw...ess-p-111.html
    Or, just open the case and make a harness to connect directly to the spades on the M2.
    Elsewhere
    I'm pretty certain that connector is part of the case, not the M2ATX.
    Yes, you could bypass that plug and wire to the spade connectors on the M2, but you'd lose the convenience of the quick-disconnect
    How about the Wiki?
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Digi-Key has the parts you're looking for.
    I spoke with their representatives and they got me the parts I needed. Links to the parts here. Pictures of what arrived.
    Edit: Never did see that MCS link, very nice. I'm going to pick one of those up and give it a shot myself!
    Mar 2009
    near Rochester, NY
    Losing the quick-disconnect wouldn't seem to be that big a problem for a test rig, but if Digi-Key has the right plug that makes things easier.
    Feb 2009
    Michigan
    I think that's a Molex Mini-Fit Jr. The plug part # is 0039012046. The receptacle part # is 0039012040.
    My local electronics shop has a blister pack with both of these parts and the terminals for just under $3.00. Don't have a part number for that.
    Mar 2008
    Canberra, Australia
    Thanks for the feedback guys, sorry for the late reply
    jpinkerton: Thanks, that is the part I'm looking for, might see if there is somewhere in Australia that has it, seems a bit silly to order such a small part from the US, but if that's how it has to go down then so be it.
    The quick connect / disconnect is pretty important and sort of the whole idea as my case is under the passenger seat, making it a bit of a pain to get to.
    I have a slightly different problem now, in attempting to troubleshoot my software issue (windows BSOD'ed and now wont resume as the file is corrupt) I have to insert a windows CD, and hit the any key to boot from CD. So when I go to plug in my PS/2 keyboard to do this, it wont get past the post screen, as I get that "keyboard error, press f1 ..." error.
    My USB keyboard will get past there no problems (I think that's cos it was plugged in when the error happened, and therefore what it is expecting), but being USB, it doesn't register when i press any key to boot from CD. So I get the same corrupt file problem and I'm back to square one!
    I'm guessing I have to pull the CMOS battery out to let it reset and then try again with the PS/2 keyboard, but that involves taking the seat out to get at the case, blah blah blah, something I would like to avoid. Anyone know a way?
    Mar 2009
    near Rochester, NY
    can you do a shutdown with the USB keyboard? Then when you restart with the PS/2 attached it should work properly.
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. WTB M1, M2, or M3 ATX power supply
    By akumar5 in forum Classifieds
    Last Post: 11-06-2008, 11:41 PM
  3. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  4. M2 ATX "D1" part dead HELP!!!
    By Elifromthevi in forum Power Supplies
    Last Post: 07-05-2007, 05:00 PM
  5. Problem m2 atx and 3.5" hard drive
    By Mitski's Rider in forum Power Supplies
    Last Post: 10-05-2006, 12:52 PM
