So just to clarify, you are trying to get teh M2 to act as just a 12 volt and 5 volt power supply to power your usb hub and monitor, and need it to follow the computer's power state, correct? If this is the case, I would power the M2-ATX off of a relay controleld by a 12 volt (yellow on drive power) in the PC, set the M2-ATX for PSU mode, and jumper it as you already have to make it always on. This way, when the PC is on, the relay will supply power to the M2-ATX, which, since the ATX PS_ON signal is jumpered, will turn on, supplying power to 12 and 5 volt devices connected.
LinkBack URL
About LinkBacks
