Results 1 to 10 of 11
Thread: Outside computer booting
    Feb 2009
    New Caney, Texas
    Angry Outside computer booting
    I am using a Dell desktop that I have taken apart and made a custom case for. I have wired everything together and I am using the power supply from the desktop. I have removed the on/off switch and am using that.
    When I first attempted to turn the PC on, I did not have the case closed switch depressed and now I get a blinking yellow light by the on/off switch.
    Does this mean the power supply is gone? I know that is what is usually what the problem is when you get a blinking yellow on/off switch in a dell.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    this happened to my computer at work, and i'm sad to report that the PS died, if you're lucky and you're still under warranty they'll replace it, if not just make sure that you don't have one of the dell proprietary connections and then buy a regular PS
    Low Bitrate Jitters333's Avatar
    Apr 2009
    I assume you used a power inverter? and you physically modded it? cuz theres no need if you have a decent inverter that stop pulling power when off, that is what you should run the relay to. here is a great place to get good cheap psu's
    http://www.newegg.com/Store/SubCateg...Power-Supplies
    but i believe dells psu's are encrypted so im not 100% if any old psu will work you should contact dell and see if you can use a commercial brand psu to run there system
    Elsewhere
    Jitters333 -
    1 - Assuming is generally a bad idea. In this case, no mention was made of an inverter or even the PC being in the vehicle.
    2 - It is impossible for a PSU to be encrypted. Data gets encrypted and there is no data going to/from a PSU.
    ekgguy -
    A couple possibilities for the blinking LED:
    - HDD activity light blinking to indicate the HDD is being accessed, which is normal.
    - A warning to indicate chassis intrusion (the case is open). I've never seen a blinking light indicate this condition, as it's usually a message on-screen. Just a possiblity.
    If this is a setup for your vehicle, and if the Dell motherboard is ATX-compliant (some Dell models are not, which is what I think Jitters meant by "encryption"), I'd get a DC-DC PSU instead of another AC-DC unit. The DC-DC units are far more efficient and eliminate the need for an inverter.
    How about the Wiki?
    Apr 2009
    Quote Originally Posted by DarquePervert View Post
    Jitters333 -
    ekgguy -
    No I'm not making things up! the psp is the same way. The psu is in fact encrypted/lock, there is even a mod on these very forums showing you how to get around that (dells, but its for one of there laptops) encryption or lock if you will
    and yes assuming is bad (*** of you me bah bah) but Obviously if he was not running and inverter he would in fact tell me so in his next post Thats why there is a ??? at the end of that comment.. there is no harm in that, god
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Jitters333 View Post
    This amused me greatly. Of course dell is going to say you can't use any other PSU than they sell (for a higher price) to power their system. They want to make money.
    I'm curious, what on a PSU could you possibly encrypt? The voltages? :P
    Edit: AH! Perhaps you are talking about the power supply identification that dell uses on their laptop chargers? The laptops still run with aftermarket chargers but they complain about it. Never heard of dell putting this in desktops.
    RevFE
    My Shop
    Apr 2009
    Quote Originally Posted by malcom2073 View Post
    ha seriously though I could swear I read something about encrypted psu's!
    whatever
    BINGO.. hahaha wow
    and thanks for not being a prick about it and giving me bad rep for making a mistake
    Jun 2004
    Westminster, MD
    It's possible I suppose they started putting this on desktops, but I would assume it would still boot, it would just display a bios warning like the laptops do. Try a CMOS reset and keep the case intrusion switch depressed, it could be it's set not to boot if the case is opened?
    RevFE
    My Shop
    Elsewhere
    The idea of power signal communications to detect a specific PSU and encryption are two ENTIRELY different things.
    Even so, I don't think it applies in this scenario based on this:
    It's a desktop, not a laptop.
    It could be due to chassis intrusion detection being set off from the original case being removed....
    How about the Wiki?
    Feb 2009
    New Caney, Texas
    the PC is not in the vehicle. I was trying to boot it inside to ensure that everything worked. Brand new install.
  1. Replies: 34
    Last Post: 05-27-2008, 09:19 AM
  2. The legalities of wardriving.
    By PURDooM in forum Wireless Communications
    Last Post: 01-29-2008, 06:26 PM
  3. Remotely turn on computer (not necessarily car)
    By Triggerhappy in forum Power Supplies
    Last Post: 06-22-2006, 01:23 PM
  4. Replies: 3
    Last Post: 03-23-2006, 05:25 PM
