Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Diagnosis MotherBoard OR PSU?
  1. #11
    Low Bitrate yam125's Avatar
    Oct 2008
    Tracy, Ca
    I tested with a DMM this morning, I only had time to test the rails, I'll jumper with the ATX cable later on today after work.
    I got a full 12.20 v on the 12v (Yellow) rail and No life at all on the 5v rail I can guess that that is NOT good.
    I know how the grounds work and I double checked the rails. [ o o o o | o x o x | x o x o ]
    I have a 80gb toshiba labtop hard drive, Rosewill Bluetooth dongle, USB audio, wireless keyboard, liliput. The audio and liliput are pluggged in at the end of a 6ft usb cable/ with a 4 port hub.
    Also a pccard, wireless network adapter.
    also for the moment of diagnostics I have most if not all usb devices unplugged.
  2. #12
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    how did the memory pop out all by itself?
  3. #13
    Elsewhere
    Quote Originally Posted by Injector View Post
    He didn't say the RAM popped out.
    He said that the RAM was specc'ed to the board and the whole setup pooped out (as in crapped out or quit working).
    The fact that you get squadoosh on the 5v rail is certainly the problem.
    How about the Wiki?
  4. #14
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by DarquePervert View Post
    LOL that's what i get for reading fast.
  5. #15
    Oct 2008
    Tracy, Ca
    So I need a new psu not a new mb
  6. #16
    Mar 2005
    Rockledge, FL
    did you use a jumper on the PSU? ad kind of voltages did you get with the PSU jumped?
  7. #17
    Elsewhere
    Quote Originally Posted by yam125 View Post
    That is my diagnoses, yes.
    With the M3ATX, the jumpers aren't going to make a difference as far as voltages. There is no jumper to disable 5v output.
    If the M3 isn't outputting 5v, the M3 is faulty, plain and simple.
    I applaud your diligence in troubleshooting, but you're delving deeper than you need.
    How about the Wiki?
  8. #18
    Oct 2008
    Tracy, Ca
    I did some tests with my DMM and did the fake turn on thing and all I had was the 12v again, nothing lower than that, thanks for your help.
    gonna get a new one.
  1. Replies: 11
    Last Post: 07-04-2009, 04:35 PM
  2. help needed motherboard wont fire up
    By alexpez23 in forum Newbie
    Last Post: 04-20-2009, 02:16 PM
  3. So how do I get the PSU to turn on on ING?
    By Emo in forum Power Supplies
    Last Post: 03-28-2006, 04:49 PM
  4. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-08-2005, 12:27 AM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:30 AM
