Results 1 to 10 of 18
Thread: Diagnosis MotherBoard OR PSU?
    Low Bitrate yam125's Avatar
    Oct 2008
    Tracy, Ca
    I have a Intel ATOM http://www.newegg.com/Product....N82E16813121360
    And a M3-ATX 125 Watt PSU
    PSU acts normal to me, but it when the MB gets signal to turn on.. the fan kicks on, USB-NO power, 5v & 12v No power and the MB refuses to turn off... unplug PSU from 12V
    What is the issue?
    Mar 2006
    Colorado, but Canadian!
    I dont understand what you are saying...
    You mean when you press the button, the mobo fans turn on, but probing the 5v and 12v rails with a multimeter you get 0v readings? That should be impossible since the mobo fans are running.
    And "refuses to turn off", do you mean the fans? Do you get POST errors? Do you get it to POST?
    I can't tell from your broken-logic post what is going on, what you have done, or what you expect it to do...
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2008
    Tracy, Ca
    I'm sorry the devices on the 5 and 12 rail don't have power and by turning it on I mean using a key to connect the connectors on the MB
    I dont even get a video signal from the board
    Mar 2006
    Quote Originally Posted by yam125 View Post
    Well that sounds like a memory or cpu problem to me. Since yours is integrated I would say RAM.
    Easy way to tell is break out the multimeter and probe the power connectors.
    Devices not turning on means diddly. Some (most of the new ones actually) require a command from the MB before they initialize to save power.
    Oct 2008
    Tracy, Ca
    Power connectors to what? Ram?
    Mar 2006
    You can't probe the RAM power connectors, they are in the DIMM socket...
    But you want to test things. So your standard molex connector has 2 grounds, a 5v lead, and a 12v lead. Probe between 5v and ground and then 12v and ground. If those are ok, I would assume the whole PSU is good. But to be thorough, you could jumper hack the ATX cable and probe all voltages including the 3.3v and such just to be sure.
    My money is on RAM. Wrong type, speed, size, or density.
    Oct 2008
    Tracy, Ca
    The ram is in spec for the board i've been using it and then all of a suddon it pooped out.
    I wantedto find a somebody witha psu tester but I haven't been able to. I have to look up how to do the jumper bc I can't probe on this psu while it is connected
    Mar 2006
    No if been using it and all of a suddon it pooped out.
    well that is another useful tidbit you neglected to mention. If you want help, you need to lay out the details instead of us trying to do it 20 questions style...
    Probe your PSU with a jumpered ATX cable, and see what the voltages are at.
    Mar 2006
    When you probe it, it should be disconnected.
    Jumper pin 14 (the turn on), to ground (any of them), and the PSU should turn on.
    Elsewhere
    In addition, some details as to the specs of your system might help determine the problem.
    Include the HDD formfactor and any/all USB devices connected.
    It's very possible that there is more power draw than the M3 can provide.
    How about the Wiki?
  1. Replies: 11
    Last Post: 07-04-2009, 04:35 PM
  2. help needed motherboard wont fire up
    By alexpez23 in forum Newbie
    Last Post: 04-20-2009, 02:16 PM
  3. So how do I get the PSU to turn on on ING?
    By Emo in forum Power Supplies
    Last Post: 03-28-2006, 04:49 PM
  4. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-08-2005, 12:27 AM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:30 AM
