Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: problem with my M4-atx
  1. #11
    FLAC WuNgUn's Avatar
    Sep 2007
    Also, aren't the mainboard switch pins polarized? I think the M4 is sensative to this...
  2. #12
    poz
    poz is offline
    Aug 2008
    i tried to connect it in both of the directions, same results
  3. #13
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    I looked again, but didn't see it, what motherboard are you using now with your M4? It should have a manual that clearly shows which pin is -/+, else sometimes it is printed in small font on the board near that pin.
  4. #14
    poz
    poz is offline
    Aug 2008
    im using gigabyte GA-G31M-ES2L motherboard
  5. #15
    Jan 2009
    Iowa
    If it's this identical one from Newegg. According to the manual you can see the + and - parts of the power connection.
    After you're sure the power lead is on proper, I'd reset the BIOS and the M4 fuse.
    And you're sure all your connections from and including the car battery to the M4 have enough juice to meet the requirements?
  6. #16
    poz
    poz is offline
    Aug 2008
    ok ill try to check it
    yes im sure because after 1 minute its working normaly
  7. #17
    Jan 2009
    Iowa
    Your car battery/wiring is all beefy enough to handle the equipment you're trying to power?
  8. #18
    poz
    poz is offline
    Aug 2008
    yes my battery is new (58amp)
    and the wiring is good and pass directly from the battery to the power supply im not sharing it with the amplifier or something
    so its not the problem
  9. #19
    Jan 2009
    Iowa
    What about the wiring and fuse on the line? What gauge and what size of fuse?
  10. #20
    poz
    poz is offline
    Aug 2008
    hi,
    its the original fuse i think its 20amp
    the wiring is very good
    but i cant find the reason for this delay
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 09:24 PM
  2. M1 ATX Problem 5v Rail Under Voltage
    By uhohrobbo in forum Power Supplies
    Last Post: 04-20-2008, 11:50 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 12:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 01:57 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 02:52 PM
