Results 1 to 10 of 20
Thread: problem with my M4-atx
    poz
    poz is offline
    Aug 2008
    hi,
    i have m4-atx power supply that was just fine,
    after changing to a new computer something is wrong
    when i switch the ignition on it takes about 1-2 minutes for the computer to get the startup signal.
    i tried to connect the pc to normal home power supply and it works ok.
    my m4 switchs set to ON - OFF - OFF - OFF
    whats wrong with it?
    thanks
    poz
    poz is offline
    Aug 2008
    please, anyone? any idea?
    Nov 2007
    try connecting the m4-atx to the computer through the usb port so that you can change the settings
    dont know why but the exact thing happened to me when I got the new MB in
    FLAC WuNgUn's Avatar
    Sep 2007
    Jeez, how many threads have I read with the title, 'Problem with my M4'??
    poz
    poz is offline
    Aug 2008
    its my first problem with the m4
    theres no other way to reset it or something?
    and if i connect it to the usb how do i change his settings?
    Sep 2007
    Have you tried pulling the fuse for 30 seconds?
    Check your BIOS settings as well...Resume on AC fail???
    poz
    poz is offline
    Aug 2008
    i tried to plug the power off for more then 30 secs its the same?
    i also tried to power it using normal pc power supply at home and it works ok
    the problem exists only with the m4
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    I believe WuNgUn was talking about the fuse on the M4. Have you tried pulling that off the M4 for more than 30 seconds to reset the M4?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use the USB program to reset it to factory defaults, THEN completely disconnect it from all power sources, including the USB line and the mobo. Wait 45 seconds and reconnect. It doesn't always register changes unless you disconnect it from power and wait.
    Want to:
    poz
    poz is offline
    Aug 2008
    i dont have a use connector i have to make one
    but ill try to pull off the puse for start and see if it helps
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 10:24 PM
  2. M1 ATX Problem 5v Rail Under Voltage
    By uhohrobbo in forum Power Supplies
    Last Post: 04-20-2008, 12:50 PM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
