Results 1 to 10 of 14
Thread: M2-ATX Powering Issues
    Dec 2006
    BK, NY
    I am trying to set-up my work bench at home and found an old Mini ATX power supply. I fooled it to power on and it does, even checked with a multimeter. My situation: I purchased a Mini ITX Carputer from ebay which already came prewired with an M2-ATX. I connected the power and switch wires together because I didn't have a switch at the time, hooked up the ground and what I notice is that the tiny green LED on the motherboard lights up for a second and then goes off. I thought the power supply wasn't powerful enough so I brought it to the car - hooked up black to ground and as soon as I connected the red wire (without white this time) to positive terminal, it "welded" itself to the terminal and the fuse on the M2-ATX blew. What am I doing wrong? I promise I searched
    Low Bitrate skeet2331's Avatar
    Feb 2005
    Indiana
    Did you have a fuse on the power wire coming from the battery? It sounds to me like you did not place a fuse within 18 in of the battery which then caused the wire to melt from the short.
    Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
    My 2000 Saturn SL2 Worklog
    Dec 2006
    BK, NY
    hey skeet2331, thanks for the reply, but I do not see the need for a fuse for a short term use. Correct me if I'm wrong
    Feb 2005
    Indiana
    You should always fuse a power wire. You created a short somewhere that is why the fuse blew on the M2. Since that fuse blew then there was enough current to melt the power wire to the battery terminal. It is always better to be safe then sorry.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    make sure you are connecting the cables to the right terminals, the instructions are somewhat misleading, follow the bottom pic not the top one
    Dec 2006
    BK, NY
    skeet2331:
    Agree about being safe than sorry! I hope I didn't short anything, but even if I did the fuse on M2 saved me.
    Injector:
    You're right the top diagram is incorrect! I noticed it right away after looking at the M2.
    Question about the switch wire - can't I just connected it directly to the power wire bypassing the switch? Also why did the LED light go on and then right away turned off after the mini ATX was connected?
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    Quote Originally Posted by kraimer21 View Post
    skeet2331:
    Injector:
    In my bench setup, the same thing was happening. green light on, then the power supply would shut off. i checked the voltage and was only getting about 9.5V on my 12V rail. odd right? Then I read somewhere that older ATX psus sometimes require a load to be on the 5V rail. So I just connected an old dvd to one of the power cables (but no ide) cable, and it booted right up.
    if the m2-atx isnt getting at least 11.2V it'll shut off.
    Dec 2006
    BK, NY
    Quote Originally Posted by roflcopter View Post
    That is very odd! My problem however is that the power supply stays on, but the LED shuts off. I will try hooking up a dvd player, or similar, see if that works.
    Feb 2005
    Indiana
    When it was on a bench test did you try it without the M2ATX? Did you put it on a normal PSU?
    Dec 2006
    BK, NY
    I'll be honest, I didn't even think about that! Good advise..can't believe I didn't think of that
  1. WTB 7" LCD, VoomPC2 and M2 ATX
    By caenis in forum Classifieds
    Last Post: 11-15-2008, 10:18 AM
  2. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 10:03 PM
  3. M2 Atx
    By Punky in forum Power Supplies
    Last Post: 11-09-2007, 11:43 PM
  4. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 05:22 AM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 01:14 PM
