Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 7805 Question for the Guru's
  1. #11
    Jun 2008
    Main Hub(powered), Touchpad, Touchscreen, OBD, GPS, Bluetooth, RF for Keyboard, Xbox360 Joypad, USB Capture for Camera, 4 Port hub(bus), 4 Port Hub(powered/accessible)
    11 Devices, so lets say 15 devices so I can utilize my accessible 4 port hub for anything on the fly.
    15 * .5A(max) = 7.5amps(max)...
    So yeah, DC-DC is going to be the way to go.... that being said.
    Which of these two units seems like the better buy?
    If I'm reading the Data sheet correctly, the Mean-well runs at 70% efficiency?
  2. #12
    Mar 2009
    near Rochester, NY
    If you already have some 7805s you could throw the circuit together and start measuring draw. I did that, and found that all the components I am powering off the hub only draw ~400mA, so I didn't even need the second 7805 I was planning on using. Plus at the ~13V to 5V drop they are good for more like 1.5A apiece. Used thermal epoxy to attach 1 7805 to a heatsink, then thermal epoxied that to a beam in my car.
  3. #13
    Jun 2008
    so back to the 7805 topic...
    My original intention was to use 4-7805s in parallel and attach an old 12v northbridge fansink. Do you think that'll do the trick, or will it need a bigger sink?
    Also, how do you measure amperage draw?
  4. #14
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    Im not one for the maths, So i hope someone else can give you a better answer for the heatsink size.
    As for the amp measuring, That can be done with either a multimeter inline with the circuit or there are some little automotive devices that basically have a LCD display and a cable that plugs into a blade fuse holder.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  5. #15
    May 2009
    Quote Originally Posted by Hellrazor978 View Post
    If you going to max out each 7805, then you need a fan/heatsink like that per each chip.
    Look at it this way, how big are the AMD Socket A heat sinks? Those CPUs dissipate ~60W when loaded, just like your 7805s when providing 6 Amps...
    Go with a DC-DC converter.
  6. #16
    Jun 2009
    Melbourne, Australia
    my advice would be to think about using a power transistor set up with only 1 or 2 IC's.
    the power transistor setups generate heat also but it is a generally simpler method in my opinion.
    similar to this
  1. A quick question for the gurus...
    By poppasmerph in forum Power Supplies
    Last Post: 05-13-2005, 02:33 AM
  2. Quick question for the Gurus
    By poppasmerph in forum Newbie
    Last Post: 05-12-2005, 06:58 PM
  3. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 12:27 PM
  4. Question For Electric Gurus
    By brentp4 in forum General Hardware Discussion
    Last Post: 02-01-2002, 07:31 PM
  5. Another inverter question...for electronics gurus
    By moahdib in forum Power Supplies
    Last Post: 06-07-2001, 08:30 PM
