Results 1 to 10 of 11
Thread: Simple 2amp 12volt Regulator
    Jun 2009
    Melbourne, Australia
    Hello there,
    while most probably already know about how simile these can be, nice images and parts required below
    useful for external power for modems, drives, or anything else with minimal power needs, with a 5volt similar model, would also power DVD drives, external HDD's.
    Parts list
    7812 IC
    2x 47uF 50Volt Caps
    2x 100ish Ohm Resistors
    2x Standard Brightness Green LEDs
    You'll also need a standard PCB, 5holes X 10holes
    Total construction size with my heatsink was 1/2inch X Inch X Inch
    1 LED for power in confirm
    1 LED for power out confirm
    1amp stable with no Heatsink
    1.5amp stable with Heatsink and 0.4v Drop
    2amp moderately stable Heatsink + Fan 0.5 - 0.7v Drop
    Next step, getting 5 - 10 amps
    Images Attached
    Jun 2009
    Further Test Results
    This Regulator is able to power my JBL 4x100watt rms amp up to approximately 50% (depending on gain) of max volume, after 50% volume amps drawn exceeds what i am comfortable with (1.6amps)
    while this is in essence a meaningless test as no one in there right mind would use a regulator on a car amp, it was useful in showing how much this amaxingly small setup can do.
    pyr0
    Jun 2009
    UPDATE:
    added a Power MOSFET in parallel to help increase amps out, thus far the largest load ive been able to find (not the units limit just the only thing i had around to plug in) is my portable car fridge that runs at ~3amp. The MOSFET is obviously resonsible for the 1+ amp increase in output
    have also added a permanent fan that uses 0.15amps of the regulated output
    New Images included
    An indicated 2.76amps which is whats expected for the 3amp car fridge
    Improved look of the unit, not as small but increased stability and output has made it somewhat expectable size increase. Also able to see the 2 LED's, foreground is the output LED, background, glow only is the input. Thought this would be a useful feature as it is yet to be fused, and helps in problem solving should this be installed.
    Unit sitting on top of the current porta-power, old motorcycle battery, first time its actually been useful.
    (also note; my sexy workbench :P)
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Thanks for sharing.
    If you are looking for a larger load try a headlight.
    I used one to compare the efficiency of a dc-dc to an inverter.
    Jun 2009
    this is with 3 headlights running off it, 6.12 amps stable and rather cool which surprised me, pushing for 10amps after i get some sleep
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    So can we have the schematic for the simple 12V 2A psu? This would be useful for those running lilliput screens, for example.
    Newbie smartass365's Avatar
    Jan 2008
    Sonoma County, Komifornia
    What about the sag in output voltage when running off a fully / somewhat charged battery at about 1 amp load?
    Wouldn't it only work when the alternator's spinning?
    How about some sort of booster converter instead?
    2003 Chevy S10
    Truckputer Progress:
    Planning.......[----------X] 100%
    Parts...........[---------X-] 99%
    Fabrication...[---------X-] 99%
    Upgrades.....[X----------] 1%
    Newbie corvettecrazy's Avatar
    Feb 2009
    NY-ish
    Quote Originally Posted by smartass365 View Post
    I was wondering this as well, since every voltage regulator that I have used requires a 1.5-2v drop/difference between input and output to work properly. Which would mean you would have to have the car running for it to work.
    It would be awesome if I was wrong, hence me asking about it.
    Aug 2009
    Port Charlotte, FL
    That's correct. For the 7812, Vin(min) is officially 14.5v, though it'll operate down to 13.5v with a 2v drop (Vout = 11.5).
    Have you considered a boost-buck converter such as the Linear Technology LTC3780? It'll guarantee Vout at up to 20A for Vin = 4 to 36 volts.
    Jun 2008
    I also made one just like it, but with two 7812 in parallell for more current.
    My PC died as soon as i turned the key off (below 11 volt) !
  1. Voltage Regulator Constant Heat
    By phita23 in forum General Hardware Discussion
    Last Post: 02-21-2005, 12:18 AM
  2. 3A 12v regulator?
    By hcker2000 in forum Power Supplies
    Last Post: 10-15-2004, 01:46 PM
  3. need a simple regulator circuit
    By oddcomp in forum Power Supplies
    Last Post: 05-08-2003, 09:22 AM
  4. DC-DC regulator and sproggy questions
    By Silmaril in forum Power Supplies
    Last Post: 12-28-2002, 07:41 PM
  5. simple e-mail software
    By felix99 in forum Software & Software Development
    Last Post: 09-21-2002, 04:29 PM
