from what i can see in the user manual (not sure if you've looked at it) it is a pulse based SSC device, meaning that like your normal computer on button, it has to only be on momentarily.
however with the "ignition override" function that this item has, once the pulse is sent, and the ignition turned on, the ignition takes over as pulse driver, thus leaving the unit on till the ignition is cut.
short answer, you should be fine
FYI personally i hate the idea of 5 channel car amps, would more recommend getting a good 4 channel and monoblock combo.
Pyr0
LinkBack URL
About LinkBacks
