Results 1 to 7 of 7
Thread: weired m2-atx what shall i do??
    Apr 2009
    after retrying a lot, here are the problem & the expected error from my view
    the psu works fine totally except giving the on signal to the motherboard
    when it is set to p1 or another setting
    1-you apply acc. the led j5 goes on the 5 v standby led of the motherboard goes on , motherboard don’t start
    2-acc off , after 5 sec approx the motherboard goes on
    3-if acc is turned on again in less than a min the motherboard turn off
    4-acc remains off after 1 min approx the psu cut power from motherboard"hardoff"
    5-after cutting the power from motherboard if I turn acc on we return to step one, motherboard don’t start automatically
    so on
    motherboard used intel d945gsejt with the 4pole p4 atx j2
    pin 14,15 on the 20 pin atx connector are jumpered as advised from mini -box to simulate the ps_on
    j8 or j9 tried both noone gives the on pulse to the mobo when acc is on
    but gives it after 5 sec of the acc off
    what shall i do with that??
    i'm stuck with it
    specs of the connected parts
    1-mb intel d945gsejt
    2-m2-atx
    3-500 gb 2.5" sata hd
    4-slim dvd-rw
    5- 2- 4*4*1 fans
    help please
    Mar 2006
    Colorado, but Canadian!
    well unjumper pin 14 of the ATX cable.
    Then did you make sure your cable from J8 has the correct polarity? If you have J8 connected, and manually short out J9 does it turn on?
    Did you test with a normal PSU inside and get it working?
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2009
    Unhappy
    Quote Originally Posted by 2k1Toaster View Post
    first of all if i unjumper pin14 the m2-atx will not power the board
    even the 5 v standby led on the motherboard wont go on
    second if i manually short j8 it turns on directly with no problem
    third i dont think that the j8 has polarity on it as it's just a short to turn on the mobo
    tested b4 with a normal ac psu with pin 14 jumpered and it works fine
    when i short the power pins it goes on instantly
    but with the m2-atx no mobo on auto signal sent while i turn the acc on"it's main feature"
    and even if it has polarity,how does it turn iot on when i turn acc off??
    thanks
    Mar 2006
    Quote Originally Posted by nohope View Post
    Then you have a problem somewhere else. The M2 is what takes care to tell the mobo to turn on. Once the mobo wants to wake up the mobo is the one that shorts 14 to grounds itself. If you are doing it, something is very wrong. Only reason to do this is to test the voltages coming out, but then you would do it when not connected to the mobo as to not risk destroying it.
    It shouldnt be on unless the M2 is on or waiting to hardoff. When the M2 is "off" it is essentially pulling the plug from the wall. So there should be no standby LED unless the mobo was on and is waiting to turn off or of course is still on.
    That is a good sign
    That's where you are very very wrong. A normal button is just a short yes. That's why the test would be to short it manually and see. However the M2 cannot short the 2 lines. It just grounds one of them. That's why the connector has polarity. Every mobo is different, but essentially when you short the mobo connector, you are pulling one of them to ground. Which, who knows. But the M2 has to have the right one, or nothing will work. So flip one end of J8 between the M2 and the mobo. Check the polarity easily that way, as it cant really damage anything, it just wont work if not hooked up right.
    thanks
    This could all be due to your funky hacking of the ATX cable. When the mobo cant decide when to turn on/off and ACPI events wont work because you kept pin 14 shorted, there's no telling what the mobo's firmware will do.
    Apr 2009
    look at the intel d945gsejt specs
    it does have a 20 pin atx connector at all
    it is powered from the dc 12v regulated power only"round small jack in the backpanel"
    or the 4 pole atx connector on it
    for sure it wont give the ps_on to the m2-atx without wires
    so that's y i jumper pin 14,15 to simulate the ps_on
    Apr 2009
    if so i wont get the benifit with the auto on from m2-atx
    & i should connect the j9 to an external switch & turn it on manually when i get in car, & it will turn off automaticly when i get out of the car
    as i dont have on the board a 20 pin atx connector so i have to jumper pin 14,15 all the time
    Apr 2009
    Thumbs up case closed with success :)
    problem solved ,
    have jumpered pin14,pin15 of the 20 pin atx connector
    power setting in the bios is to power on when current restored
    so it starts automaticly when i turn acc on
    & it's allready shuts down automaticly when acc is turned off
    seems that when i jumper pin14,15 the mobo conflict in turning on automaticly from the m2-atx
    so the final solution was from the bios
    thanks to 2k1toaster
  1. hooking up amp remote wire to m2 atx
    By mm87 in forum Car Audio
    Last Post: 07-16-2009, 03:11 PM
  2. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  3. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  4. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
  5. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
