Yes it will be able to power your ATX mobo, and it does have a shutdown controller built in. I just received mine a couple of days ago, and am waiting to install it!!
Hi, i came across this site about a year ago and finally decided it's time for me to get a PC in my car.
After some planning and a litle work i got a primative PC up and running in my car only to have the window smashed in and the system stolen
Anway, i've leaned from my mistakes and now id like to build a better system (and hide it when im parking in big lots)
Im thinking about getting an Xenarc VGA touch screen, using an old gateway pc, and sticking in an Opus DC - DC PSU
Im very new to this but i was told that some Opus models would be able to power my ATX mobo as well as shutdown the PC and Start up the PC with my car staring and shutting down
Is this true?
Such is life....
So that means it will be able to gracefully shutdown my PC when the car turns off?
What about when the car turns on? Will it be able to turn the PC on?
turn on the "power on after power failure" option in your bios settings, that should work...
Bluevisor....that's not correct....
Opus will turn on when your car does...and shutdown the comp. 10 sec. 10 min or 20 min. by using different jumpers....
OPUS KICKS A$$
I have one...and I'd buy another if I was donig it again!
BossTone74
So say i run over the market to get an apple, if i set the jumper to turn off after 10 mins, and im only inside for 8 mins, when i come back and turn the car on, the PC will still be on?Originally posted by bosstone74
YES, that is correct!!
What I did and a lot of other people, they keeped it on the 10 sec. shutdown and made a switch to keep it on in that kind of situation...
BossTone74
how does leaving the computer on for that 10 or 20 minutes effect the battery?
also, are there any cheaper alternatives to the opus, its rather expensive (i was quoted 189)
There a bunch of cheaper solutions. But what opus did is it made a psu that was very easy to install and use. Another road you could take is get a psu and a seperate shutdown controller. If you want the cheapest solution than build one yourself or ask someone to build you one.
Maroon Monte Carlo In process of Being Pimped Out.
where would i inquire about having one built for me?
