Have you measured voltage on your constant 12v line and your ignition-controlled line both with the ignition on and ignition off?
Something isn't right with the voltage, I'm guessing.
A flat battery could be the culprit. Measuring the voltage will tell you if that is the case.
LinkBack URL
About LinkBacks
