Results 1 to 7 of 7
Thread: 2140 issue
    Jul 2009
    2140 issue
    I have Xenarc MP SC 8 and ran it off a 1900 for years. The 1900 gave out about a month ago and I just installed the 2140.
    It worked on the bench but when I installed into the vehicle I noticed a bad smell and then a tad of smoke coming out of the 2140. I immiediately pulled the power from it.
    Now it makes a strage whirring sound and it is not the fan, rather the 2 small cylindrical components by the output plug. It powers on and the LED comes on/blinks, but it will not power the computer. I plugged the computer into the wall and it is still working.
    Any ideas?? p.s. I made sure the DLYON was not shorting on anything as well...
    One other thing, I changed the hard drive in my Xenarc from a 60g 2.5 t a 120g 3.5 Is this causing a startup issue possibly and hard on the start up controller??
    Jul 2009
    anyone??
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Have you tried to hook it up to a PC via USB? The PSUmoni application can be found here: http://carnetix.com/firmware/PSUmoni2140V1.8.3.zip
    It's also probably worth posting on the Carnetix support forums.
    ptk
    ptk is offline
    Singapore
    fuse?
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    Jul 2009
    hooked it up PSUmoni shows connected but no status lights. Checked the fuse too. I get the LED light on the unit, but no power to the computer.
    Feb 2006
    Melbourne, Australia
    Can you take a pic of the components? Is it black cylindrical (diodes) or aluminium-covered-in-a-plastic-sheeth cylindrical (capacitors)
    Do not use this to power your carputer before we ascertain what the problem is...it may cause unwanted problems.
    If you smelled burning components, and saw smoke, you fried something.....
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Jul 2009
    It was the capacitors that were smoking. Fortunately I unplugged it quick. I bench tested the computer afterwords and it is still good. Already sent the 2140 back for repair/exchange.
  1. DigitalFX 4.0
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-27-2014, 05:48 PM
  2. **Please help!! disk drive/windows issue
    By Phoenix750 in forum General Hardware Discussion
    Last Post: 05-12-2009, 12:38 PM
  3. HP Laptop LCD Exstension issue
    By kendallb in forum LCD/Display
    Last Post: 03-22-2009, 07:16 PM
  4. My RR/DFX 4.0 100% CPU usage issue
    By Minoritydan in forum RR Bug Tracker
    Last Post: 12-23-2008, 01:40 PM
  5. No audio after resume from hibernate issue - almost fixed - Help me finish?
    By Trin in forum Software & Software Development
    Last Post: 07-26-2008, 08:35 AM
