Results 1 to 6 of 6
Thread: Opus 90W dead?
    Oct 2006
    Opus 90W dead?
    Hey ppl,
    So i was playing around with some wiring in my car yesterday and now my car pc no longer works.
    After some investigation and getting it out the boot! i managed to find that my opus 90w psu has blown a fuse. So i got a new one and put it in.
    Since i have a bench supply i brought the pc inside and hooked it up to my 12v supply and tried again. I fired up my power supply which put 12v onto the switched and live and gave it a 0v line. The ignition light on the psu works and flicks on and off...the power light on the mobo lights. However, then the pc tries to turn on (either by the opus providing an on signal about 5 seconds after turn on, or by me just pushing the power button, i tried both!).....then light on the mobo just dies out as if the power supply can't cope.
    I don't know whats wrong, there is no obvious blown components.
    Any ideas?
    Thanks guys
    Oct 2006
    any ideas?
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    You may be pulling too much power from the Opus.
    How many times does the light on the Opus blink?
    Interpreting the Green Status LED light flashing
    0.1 sec ON and 2.5 Sec OFF: DC-DC power supply is in Idle or stand-by state.
    On constantly: The PC is powered and the PC should be operating.
    Number of flashes: Reason for flashing:
    1 Flash: Battery voltage is below normal operating range.
    The normal range is 11.5 VDC to 18 VDC.
    During engine cranking the low battery voltage detection is ignored so the battery voltage can dip below 11.5V.
    2 Flashes: The computer power up sequence failed.
    Reasons:
    1. Check the wiring of the two wire power-switch cable from power supply connector J9 to power switch pins on the ATX motherboard. If connected properly check the polarity of the power switch pins. May be reversed.
    2. Check ATX mother board bios settings.
    3. Locked up mother board or software crash of bug.
    4. Faulty DC-DC power supply.
    3 Flashes: Power supply output voltages are out of normal voltage range.
    Reasons:
    1. Power supply output is over loaded or shorted.
    2. Faulty DC-DC power supply.
    4 Flashes: Power down, stand-by or hibernate sequence failed.
    Reasons:
    3. Check if ACPI function is enabled in the power management BIOS setup.
    4. Make sure ACPI drivers are installed in the operating system.
    5. Check if application is compatible with ACPI mode of operation.
    6. Locked up mother board or software crash of bug.
    7. Faulty DC-DC power supply
    After a 2 year break, I'm back! There are so many new and familiar faces here!
    New vehicle, new ideas!
    Chryssi - The Changeling CarPC Project
    Oct 2006
    thanks for the reply, the psu flashes twice then waits, the flashes twice again.
    The mobo works fine when plugged into a mains psu...
    May 2008
    Oct 2006
    Quote Originally Posted by freeflashstuff View Post
    tried both ways round and also tried it by just shorting the pins on the mobo
    must be ok if booting from a mains psu
    same as 2.
    maybe?
  1. Dead pixel fixed?
    By Fox_Mulder in forum LCD/Display
    Last Post: 01-31-2005, 04:48 AM
  2. 90w power supply test
    By linden_arden in forum Power Supplies
    Last Post: 01-05-2005, 01:42 PM
  3. M10000 - Dead Dead Dead , 4 hours lol
    By Bikr in forum General Hardware Discussion
    Last Post: 05-23-2004, 02:37 AM
  4. Think this Opus 90W is dead?
    By ZenerDiode in forum Power Supplies
    Last Post: 04-26-2004, 03:05 PM
