Results 1 to 5 of 5
Thread: Dual Sproggys
    Mar 2003
    Question Dual Sproggys
    Has anyone tried to run dual sproggys a modern ATX mobo?
    Mar 2003
    dual power supplies
    You know, I see this sort of thing a lot. It really doesn't work well.
    The power supply works by measuring the voltage at the output. If you have 2 of these with the outputs connected together, one is going to have a slightly lower threshold than the other one. This device is the one that's always going to be supplying juice while the other one with the higher threshold is essentially off.
    This will continue until the lower threshold device overheats and shuts down.
    Even if you split up the 5V wires between the power supplies, they're still connected on the motherboard. There may be enough resistance between them so that it works OK, but it's not guaranteed.
    FLAC Mastero's Avatar
    Aug 2001
    India
    DIODES
    is the key word here ... !
    so no return is allowed ... .. think about it ...
    Mastero
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    Originally posted by Mastero
    DIODES
    Mastero
    Are you willing to take a .7 volt drop for every diodes used? There are resistances to diodes too which in turn will produce heat. Doesnt the PSU send ground signals to the motherboard and vice versa so the PSU knows the mb is on? After you diode and isolate the 2 PSUs the motherboard sees 11.3v, 4.3v and 2.6v.
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    I've used dual sproggies, with no problems. They were isolated from each other tho.
    One up front powering the lcd and dvd drive (no 3.3v rail needed).
    One in the boot/trunk powering the motherboard, cpu and HD.
    Never tried connecting the outputs together tho, and I`m not sure if i`d want to now.
