i don't see any problem with that... in fact i have 2 gauge wire to my distro, and i use 8 gauge from distro to my m2-atx
I have a 4 gauge to 8 gauge distribution block going to my trunk. Is it okay to run that 8 to my m2-atx or should I use 10?
"You know what I mean? But at the end of the day, it is what it is." - The most articulate thing someone could say.
I just purchased an M2-ATX and it came with 16 gauge leads. The charts show that good for 22 amps for chassis wiring, which is more than you are going to draw unless something goes drastically wrong, but you'd blow the fuse first.
8 or 10 are overkill but will certainly work.
Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
