Results 1 to 3 of 3
Thread: carputer starts up then shuts down while using opus & power pin 6/8
    Apr 2005
    Hi all
    my Opus 150watt psu is hooked up to my carputer
    but if I use the green/white wire to pins 6/8 (respectively)
    the carputer starts up windows then shuts down again
    While the setup was being built on the bench I just used a simple momentary switch connect to pins 6/8 on the MB to start and shut down the pc
    I think the Opus is sending a constant signal and not a momentary signal which is causing the shutdown
    my motherboard is a Intel D845GRG and based on the PDF diagrams on the intel site I am using the correct Power switch pins and not the reset pins
    Any ideas?
    thanks
    Elsewhere
    Try reversing the polarity of the green/white wire.
    How about the Wiki?
    Apr 2005
    Quote Originally Posted by DarquePervert View Post
    yeah tried that already, the system won't even start when I did
    so far, I've rigged up a momentary switch in the car with wires leading to the trunk, not the best, but it's working for now
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 11:58 AM
  3. Opus 90W Power Connectors / Cables
    By kevpriest in forum Power Supplies
    Last Post: 07-31-2006, 07:00 PM
  4. WTB: 20 pin ATX Power Cable for Opus 120
    By Shelbrain in forum Classified Archive
    Last Post: 02-04-2006, 02:23 PM
  5. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
