Results 1 to 6 of 6
Thread: Power Supply Recommendations
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    I have a Opus 150watt from when they first came out. It's worked GREAT over the years. However I have recently purchased a new motherboard and a dual core e5200 and 4 gbs of ram. I hooked it all up and the fans started and turned off and back on then off. Then I start the car and it powered up and booted into windows.
    I need more power. I would like a power supply that acts just like my opus, but obviously need more power. Obviously something reliable and easy to set up.
    What do you recommend?
    I was thinking of something in the 250watt range. That should do it.
    BossTone74
    Elsewhere
    DSATX. You can't go wrong.
    How about the Wiki?
    May 2002
    Japan, Oregon
    Thanks! Anyone else want to chime in?
    BossTone74
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    Quote Originally Posted by bosstone74 View Post
    Ok, just remember you asked...
    I was suggest a dc-dc power supply... from the mp3car.com store...
    I also suggest, Hot Dogs be eaten with Hot Dog Buns.
    And ferther mor, you could take that 150watt and run it in seer-ez with another 150watt and get a 300watt supply!
    MUAHAHAHAHAHA 5:00o'clock cant come fast enough!
    How many useless post is that today? ha ha I'll quit I promise...
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    May 2002
    Japan, Oregon
    Quote Originally Posted by SjLucky View Post
    Thanks...and you were right, useless...
    Don't post anymore, you are are on Post #666
    BossTone74
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    p2140
    or a new opus
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  3. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
