Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Mini-Box and their products: My Opinion
    Elsewhere
    My opinion of Mini-box has been degrading over time.
    My bias is definitely against Mini-Box because of various issues with their line of power supplies. I know there are many who use an M1 or M2 and have for quite some time without an issue. There are even a couple happy M4 users out there, I believe.
    However, there have been enough issues with their products, deceptive specifications and design flaws, that I have a hard time trusting Mini-Box as a company or their products.
    Understand that I have never owned or used a Mini-Box product. I have seen them in action and functioning, so I'm not going to lie and say they don't work or that they are crap (except, perhaps the PW-200 and early PicoPSU). I will say there have been enough issues across their entire product line that make me want to avoid their products.
    It all started with the PW-200.
    This model was on the market before I got involved in the hobby. This PSU is rated for 200w output and ATX compliant. It's one of the tiny PSUs that is the size of the ATX connector with a small circuit board that sits parallel to the motherboard.
    The form-factor is great, but....
    First of all, it requires regulated 12v, so using this PSU in the car required a separate 12v regulator. At the time, the commonly used ITPS could put out 12v @ 5A. That limited the PW-200 to about 60w output, and was suitable for the EPIA M10000 series as long as you reduced the 12v peripherals to an absolute minimum.
    In their defense, I don't think Mini-Box was considering the vehicle PC market when they designed the PW200M. I believe it was intended for those looking to make utilitarian PCs based on EPIAs low-power motherboards to use as file servers, networking devices or other functions where CPU power isn't a major issue.
    At the time, it was a start in the right direction...
    Next came the M1-ATX.
    The M1-ATX was avtually a good power supply. Sure, it was limited to 90w, but it was ATX compliant, included a startup/shutdown controller and did not require regulated power.
    That's all great stuff, but it was overshadowed by the 150w Opus model. The Opus was better because you could use it with a wider variety of hardware because of the higher output, plain and simple. Never mind that you could get an Opus 150 as a bare board or in an enclosure to fit the popular Shuttle cube-style cases.
    It's not that the M1 was poor quality at all. It was simply beaten by Opus Solutions.
    So Mini-Box created the M2-ATX.
    This was the answer to Opus 150w trump card.
    The M2 provides 3A more on the 12v rail and a 4-pin P4 aux power connector as well. Granted, there is 2A less on both the 3.3v and 5v rails of the M2-ATX than the Opus 150, but the ability to power a wider range of devices requiring 12v is a huge selling point.
    But there are problems. It it well-documented that overloading the M2 will kill the PSU, but can also kill your motherboard, as well. Most PSUs will simply not power the components if the draw is more than the PSU can handle, but the M2 was destroying motherboards.
    And then there's the problem of the 4-pin P4 power connector. The 4-pin P4 power connector on the M2 was oriented that the latching mechanism was right up against a capacitor, and simply connecting the P4 cable to the M2 risked breaking the capacitor from M2's circuit board. Sorry, but that's just crap design.
    This photo from the Mini-Box website shows the connector on M2. The orientation of the latch is right next to that capacitor:
    I apologize for the excess whitespace. This is an unaltered image of an M2 straight from their site. Click the photo and it links to their image. Or follow the link to the product page on their website and see for yourself. This isn't some photochop to make them look bad.
    I believe the design flaw has been corrected. The photos of the M2-ATX-HV show the P4 connector oriented differently, so I am guessing the design has been modified to correct this issue. Still, it should never have been an issue in the first place.
    After that, the PicoPSU series hit the scene.
    The first generation of PicoPSU units were no better than the PW-200, really. They required redulated 12v, making them almost useless for a vehicle install.
    And, considering there were a number of other PSU models available that were far more capable at a similar price point at the time of the PicoPSU's introduction, The PicoPSU was silly.
    Second-generation PicoPSUs don't require regulated 12v, but they do require a minimum of 12v input (the operational range is 12-25v), so vehicle use isn't really an option unless you are only going to power the PC with the engine running or from a second battery. And forget about surviving engine crank!
    But with faster, more power-hungry CPUs dominating the scene, a 60w, 80w or 120w PSU doesn't make a lot of sense.
    Of course now that the Atom processor and similar low-power CPUs on the horizon from AMD, the PicoPSU is starting to make sense, especially with its tiny form-factor. It seems to have come around full-circle.
    I personally believe that the only viable PicoPSU unit is the 120 unit, and even then, you're limiting yourself. If you want to upgrade the PC to something more powerful, you need a new PSU, as well. Seems a bit wasteful to me.
    Very similar to the PicoPSU is the M3-ATX.
    This is a product I genuinely don't understand. It has very similar specs and formfactor, but has a lower minimum required input voltage, making it more suitable for vehicle use.
    Still the 125 max output is pretty limiting. Sure, it says 150w peak, but that's similar to the peak ratings on speakers, too. You can not continuously run at the peak.
    Again, with low-power boards based on the Atom CPU, this could be a viable PSU with a well-planed system that doesn't include many bells & whistles.
    And now we have the M4-ATX.
    When the M4 hit the scene recently, I was impressed, actually. The 250w output was perfect for just about any system.
    And then they started failing all over the place. Read all about it right here. It upset a lot of people, especially since the M4 has a pretty hefty price tag.
    As I understand it, the M4 issues have been resolved and Mini-Box (or their resellers) are very good about replacing/repairing them.
    The M4 is the newest of their product line, so I think the verdict is still out.
    One interesting thing I see with the M4 is the availability of an ATX formfactor enclosure for the M4. I hadn't seen this before, but I think it's a great addition, especially for those who want to use an ATX case for ease of installation and/or removal. RFI shielding for a PSU is also never a bad thing. It seems to me that Mini-Box learned something from their competition.
    So that's why I don't trust or recommend anything made by Mini-Box.
    I'm sure there are fanbois that use one of their products that have a differing opinion, and that's all cool. We all know about the comparison between opinions and sphincters.
    The M-line of DC-DC PSUs is pretty popular and has shown great success, but not without some pretty severe bumps in the road. I don't know about anyone else, but I don't want to risk my project, my hardware, my money, my time or my sanity on that bumpy road.
    So discuss away. Flame me. Flame those who disagree with me. Post-whore this muthah up. Whatever.
    How about the Wiki?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    very concise and IMO accurate article. You could add severe RFI issues and the 12v amp turn-on that only output 6v to the list of problems on the m2. Neither has been fixed AFAIK
    Live mp3Car Facebook Chat
    Jan 2008
    very nice write up, and i agree on the radio interferance issue.
    every person asking what power supply is best for them should see this- so even if they choose to go with a m-series, they have a idea on the common problems that they may or may not have.
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    One of the values of this forum is and should be that it motivates companies- sometimes with a carrot and sometimes with a stick- to deliver better products.
    I have let Mini Box know about the thread and offered that they hop on and work with forum members to address these issues.
    In particular i has suggested that they let mp3Car run beta tests of their products before they launch, and we can even do some for products that have been on the market, but have issues. This way, they can make sure that their products work as expected, before they market and sell new items.
    Feb 2007
    netherlands
    that's a good idea Heather
    Elsewhere
    Quote Originally Posted by soundman98 View Post
    I'm not convinced the M2 is the ultimate cause of RFI in peoples' setups, though.
    It might be or it might not.
    I have no experience with it, so I am certainly not one to judge.
    The thing is, though... There really is no "best" power supply. They all have their uses, even mini-box's products.
    There's a reason the Voom case and itswas designed to accept the M1 & M2 units, after all.
    How about the Wiki?
    Woodbridge, VA
    Blog Entries
    32
    I'll be the one to judge then. After 4 cars with different antennas, 3 entirely different systems with entirely different components per system the only constant is the m2. I can leave the m2 in the trunk and wire it to the pc inside the cabin and hear a clearly audible difference in static when i have my seats up vs. seats down. If i disconnect ONLY the atx cable from the m2 and connect a standard atx PSU radio's clear as a bell.
    Quote Originally Posted by DarquePervert View Post
    Elsewhere
    Interesting....
    I wonder, though, if the EFI is coming from the 20-pin ATX cable, though and not the M2 itself...
    Just a thought, and also why I tossed out the idea of the techflex stuff to minimize the EFI.
    How about the Wiki?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Interesting write up, especially from someone who has professed to have never owned or used any of the products being dissed.
    So basically all that lovely critic and information is all based on heresay.
    So in fairness I request that DP does similar threads for all the Automotive PSU suppliers so all can be equally maligned
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I stopped reading right there.
    DP You of all people should know, that when stuff breaks, people whine. When stuff works perfectly, they're silent. So judging by the amount of negative comments about mini-box in proportion to the number of users, vs the number of negative comments about the opus (for instance) and the proportion to the number of users... I think the product line is doing rather well. You can't judge a product purely by its faults, because humans by nature are whiny. Especially forum members (not this forum, just online forums in general). Especially if you have never used or owned one.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
Tags for this Thread
