Almost that simple depending on the relay. An amplifier remote-on uses very little power (with the exception of some like RF punch or really old ones). Do you have both amp remotes connected to the M2-ATX and it won't turn them on, but will turn either one on? The problem is that would be less than what it takes to power a standard automotive relay. Most amps are around 25mA and no greater than 50mA. The bosch type relays use over 120mA so you would want a higher ohm coil at least (and clamping diode so you don't blow the remote-on output).
Something like this: http://www.allelectronics.com/make-a...D-RELAY/1.html
Ground one side of the coil, 12V to the other side, plus one side of the contacts (common) and amps to the normally open contact. Diode connects to the 2 sides of the coil as well like gnd ->|- 12V
Another option which would reqiure much less power would be a 200mA darlington optocoupler and resister. It uses an LED and phototransister instead of coil and contacts. It doesn't handle as much power on the output but should work well.
LinkBack URL
About LinkBacks
