Results 1 to 10 of 10
Thread: Does Zotac IONATX A-U still need a regulator
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    I am going to purchase the Zotac ION A-U which has an onboard PSU. I was wondering if anyone has done an install with this unit and if connecting it to the P2140 would be redundant or unecessary.
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    i dont know about the regulator, but if you get the board get it from newegg.com or tigerdirect.com
    save some $$$ for beer
    im pretty sure though u need one ... i would go with B-E board and get one of those m2-atx (i think thats what its called) power supplies
    Nov 2008
    Ahmedabad, India
    Why are you going for on board PSU model ? Get the B-E model. which has 20 PIN connector.
    I am using D-E model. and it works like a charm with 160W DC-DC PSU.
    Feb 2008
    I think onboard psu can not operate in car. I don't think it can ragulate the car 12V.
    Also in time you can need more powerfull psu or onboard psu can break down. Tou won't be able to use another psu if mainboard doesn't have any pins. Also m2-atx is around 70 dollars. Intel atom mainboard is also around 75 dollars. Combination of the two is cheaper and safer I guess...
    Elsewhere
    The board requires 19vDC.
    You need a power supply that can output 19vDC. An M2 can not do this, as it outputs the 3 voltages ATX compliance requires (12v, 5v, 3.3v).
    A Carnetix P1900 or P2140 is the ticket here.
    Do you need to regulate the power from the car going into the Carnetix? No.
    nisarg86 is correct. The B-E variant has the 20-pin ATX connector, which will work with an M2 or any other ATX-compliant PSU.
    How about the Wiki?
    Dec 2007
    AZ
    Thanks for the feedback. I will keep all of this in mind.
    Feb 2007
    Macclesfield, UK
    Thumbs up
    I am constructing a Car PC at the moment and have the same board.
    I have used a universal 12V Laptop PSU. Comes with all the bits you need and you just set its output to 19VDC.
    Good Luck!
    Andy
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    I am running the D-E version with a M4 atx and this motherboard is sweet!!! To say the least. I thought about purchasing the one with the built in pwr supply but it seems like too much of a hassle, glad i didnt. The problem i see is the fact you dont have start up shut down control. It would be perfect for home entertainment use but not very practical for automotive. So i would suggest the D-E version, pls it comes with built in Wireless N.
    Dec 2007
    AZ
    Quote Originally Posted by AndyWhittaker View Post
    Good Luck!
    Andy
    Laptop PSU? So what do you do about start/shutdown control and anti-thump?
    Dec 2007
    AZ
    Quote Originally Posted by david69leonard View Post
    I purchased the Intel D945GCLF2D Mini-ITX instead, but regarding the M4 ATX, I have been considering that one. So how has it been working for you?
  1. Simple 12v regulator question
    By aalouie in forum Power Supplies
    Last Post: 01-14-2009, 10:23 AM
  2. PW-200 V and Regulator Question
    By VehicrossPC in forum Power Supplies
    Last Post: 02-02-2006, 12:16 PM
  3. Voltage Regulator Constant Heat
    By phita23 in forum General Hardware Discussion
    Last Post: 02-21-2005, 01:18 AM
  4. FS: Morex Car Power Regulator Kit (Brand New)
    By migel628 in forum Classified Archive
    Last Post: 04-07-2004, 12:26 AM
  5. Idea for a cheap 12 voltage regulator perhaps...
    By adamis in forum General Hardware Discussion
    Last Post: 09-11-2003, 08:31 PM
