Results 1 to 10 of 10
Thread: Opus Ignition line
    Oct 2002
    Georgia
    Opus Ignition line
    When you hook up the opus where do you hook the ignition line to? Does it goto the accessory line or what, because I tried hooking it up to mine and no luck. I was hopeing I wouldnt have to wire another wire up to the front of my car.
    -Merc
    1996 Jeep Grand Cherokee
    [:::::::::.]99.9%
    Working On: Fixing wireless network interference
    Specs: 8.4inch vga touch, 1.?? ghz, 256 DDR, 4gig OS HD, 120gig Media HD, opus
    Feb 2003
    Rayville, LA
    It just ties into any line that is powered when the ignition is turned on, right? I don't have an Opus (yet ), but that sounds right to me... but what do I know
    Cordell
    Oct 2002
    Georgia
    Which would be the accessory line, so I thought
    -Merc
    [:::::::::.]99.9%
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    I've been talking to Kris from Opus lately about another situation but he says to go off of the ACC line.
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
    Oct 2002
    Georgia
    So the accessory line? As in the same line that my amps are hooked up to that tells them to turn on? Yeah tried that and it didnt boot. Is there anything that I am missing? maybe jumper settings?
    -Merc
    [:::::::::.]99.9%
    Jan 2002
    Chaska, MN
    hook up a meter on the yellow line at the opus and see what it reads, it should be greater than 11.5v
    Ebay Stuff For Sale
    Newbie Mongrat's Avatar
    Mar 2003
    the keyword is "AMPS" mon,
    you may be using up too much juice, if your using multiple amps you'll probably have to use a relay soon.
    May 2002
    Sef'Kylar
    you might have the power button wire crossed up.. the polarity matters! I had a similar problem.. all i had to do was turn the power button wire around (it only connects in one direction on the supply, try turning around on the mobo)
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Oct 2002
    Georgia
    I have tried both ways on that lil power button cable. I think it is the fact that my speaker and my sub amps are pulling to much juice from the acc line. Anyone wanna explain to me how to use the relay thing, it would be greatly appreciated.
    -Merc
    [:::::::::.]99.9%
    Mar 2003
    Relays.
    Basicly, what your doing is running 12V Constant power into the relay, then you are running a single "Ignition" or "accessory" wire to the relay. then on the output of the relay you run a wire to a power distribution block or somthing. Then, you use this "Out" as your new source for Accessory or "Igintion" wires.
    When you buy a relay, they usually have a schematic to look at.
    this way when you turn your CD player or Ignition on, it turns the relay on which gives your new accessory wires full juice/12V Direct.
    Its like a switch.
    Sorry if this email is cornfusing, Im not so good at explaining!
    ~Mongrat
