Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Are the M#-ATX PSUs supposed to be avoided like the plague?
  1. #21
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by sergatiuk View Post
    well... i expected that most of you guys are not going to like my post.
    and yes the inverter route is "longer", less efficient, noise issue is the simplest thing to eliminate with an inverter, and it WORKS ! ALWAYS !
    i agree that these PSUs have more functions, bbut they are still overpriced, yes the same way as LCD, and yes it is because of the demand on them.
    still most of our projects are a bit pricey to start with, but that doesnt mean we will pay ANY price for these devices, some of you might.
    and regarding china, its an excelent point, i have a list of manufacturers in china and taiwan, im going to email them the requirments and see what kind of pricing they can quote me...
    and guys, stop flaming me, i clearly said "personal opinion"...(;
    So explain how a standalone inverter can automatically start and stop a pc. And since they cant, how much would it cost you for a startup/shutdown controller for them? Is it still that cheap of an option?
    I don't think anyones flaming-just expressing opinions
  2. #22
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I've had an M2-ATX in my first install that I transferred over to my second install (for a total of 3 years)..
    I also just bought another M2 for my wife's new vehicle.. So yea, I like the M2's and I think they are worth the money..
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #23
    Sep 2009
    Im going to be ordering a handful of M2ATX power supplies for a few carputers I am building... hope I dont have any issues. Ive never used one of them longterm on a daily basis...
  4. #24
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    Quote Originally Posted by justchat_1 View Post
    i made this controller about a year or 2 ago, its a simple relay,capacitor circuit, you can find the schematics here on the forum, i dont remmeber the exact thread. the total cost of it was $5-$10, in my setup i used a laptop, so its the perfect combination, because it has an internal battery that is more then enough to put the lappy into hibernate after the power is cut out.
    now in a case of a standalone mobo, the easiest way to achieve this is with 2 raly modules, one to start it on ignition and the other to cut the power to the inverter after the mobo goes to hibernate, this cab be achieved in a few ways, put a relay on any mobo output - a 5V relay on a USB port, a 12V relay on a firewire port, or 4 pin connector from PSU or any other connector. and once power to the port is cut the relay cuts the power to the inverter, so you dont drain the battery...then again on IGN/ACC the relay powers up the inverter and the relay module with the capacitor sends on signal...
    basicaly, in short its a total of no more then $15 at the shack...
    noise problem is solved by grounding the pc case and mobo to chasis.
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
  5. #25
    Mar 2006
    the ONLY drawback of this setup is efficiency...
    but simplicity, durability and reliability is the end result of this setup.
  6. #26
    Dec 2006
    I'm not taking up for this guy....But I use a 200w $10 cheap *** inverter from fry's on my amd3000 for a yr1 or 2.
    As for your Q(So explain how a standalone inverter can automatically start and stop a pc. And since they cant, how much would it cost you for a startup/shutdown controller)
    It's call use two of these ELK-960 Delay Timer that I got for $10 each. This was 2yrs ago.
  7. #27
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Thats exactly what I was going to say-except for the last three....i think simple would be a single board you have in your case that handles everything -> not an inverter two relays and a transformer. Same comments about durability and reliability for a single component solider state board verse the inverter based setup.
    soloxp:
    there about $20 these days:
    http://www.google.com/products?hl=en...-960&scoring=p
    Two of those (make that three if you want amp control)...plus the price of the inverter, plus the hackjob wiring solution, huge potential for noise (inverters generate noise in both directions) and complete lack of fail safes....is it really worth the $20 savings? For me it wasn't, but then again my carpc is in hybrid suspend most of the time. Again thats my opinion, obviously others may disagree.
  8. #28
    Mar 2006
    Thats exactly what I was going to say-except for the last three....i think simple would be a single board you have in your case that handles everything -> not an inverter two relays and a transformer. Same comments about durability and reliability for a single component solider state board verse the inverter based setup...
    lol you are right, but that isnt the simplicity i was refering to. yes you have more wires and devices, but by simplicity i ment that the devices in use are simple, there is no programmable PSUs, no timings, and no complex circuit boards that as we already discussed cannot be made for $10 lol. inverter, transformer, a couple of relays and a couple of capacitors.
    one of the reasons why cars are built of many small parts and not one solid piece is because things do "go wrong". in which case you would replace the broken part and not the car. this applies to my setup. if something go wrong i replace a $3 relay,or a $0.5 capacitor or a $20 inverter, not a $90 power supply. personnaaly i prefer to rely on a few simple and cheap components then one "overpriced" one.
    also, as i said, noise is eliminated by grounding the pc case and the mobo to chassis. you would be surprised how many threads and posts ive seen here of people having noise issues with the DC-DC PSUs
    the bottom line, a PSU is a matter of preferance, one might choose to go the easy route and grab a DC-DC PSU while another might find it better to go with a cheaper inverter option.
  9. #29
    Dec 2008
    you see a lot of complaints because a lot of people have them. $70 for an m2 is a fair price, they are well designed and very reliable when used properly.
  10. #30
    Aug 2008
    Northern England
    Never had a probelm with my M2-ATX, probably the only part of the install I can say this about.
    Wired it in and forgot about it.
    No chance I would swap it for an inverter and all the work that's involved there, not to mention the size difference.
  1. Dead ATX PSU(s)
    By kefka_killer in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:13 PM
  2. BLEW two ATX PSU's with inverter?? HELP!
    By aznblueeboi in forum Power Supplies
    Last Post: 04-06-2004, 08:13 PM
  3. 250 W DC-DC ATX PSUs from JENLOGIX
    By docfx in forum Power Supplies
    Last Post: 11-10-2003, 01:41 AM
  4. anybody have any knowledge on ATX psu's
    By marsjell in forum Power Supplies
    Last Post: 04-29-2002, 10:28 AM
  5. DC/DC ATX PSUs?
    By gguy in forum General Hardware Discussion
    Last Post: 01-11-2001, 11:47 AM
