1 - Xenarc monitors don't require regulated power, last I checked. Lilliputs do require regulated power. Check the specs of your monitor to be 100% certain.
Granted, regulating the power to a Xenarc that doesn't require it would not hurt anything. It's just unnecessary.
2 - Most (not all) USB hubs require 5v power. The regulator would only work with a USB hub that requires 12vDC. A USB hub that requires 5vDC can be powered from the PC's power supply.
3. That regulator will not keep powering devices during engine crank, as the voltage would drop below the 13v threshold. An engine cranking will show voltage drop to 8-10v, typically. I don't know if that is anything important to you or not.
LinkBack URL
About LinkBacks
