Results 1 to 5 of 5
Thread: Use a Pico 90 for display PS?
    Sep 2009
    Hi Guys,
    I recently purchased my first components for my Truckputer-
    The CPU is a MCS-BB-350 from MO-CO-SO.It comes with a Pico 90W PS that I expect is a bit underpowered for what I'll be hanging on it, so I purchased a M4-ATX PS. It won't fit in the case (no problem) but I am removing the PICO as you would expect.
    Can I repurpose this baby PS to use as a regulated supply for my 10" touch screen?
    Any thoughts or comments?
    Larz
    Elsewhere
    If the screen requires 12vDC (Unlikely that the TS would require 5vDC or 3.3vDC), then you can, but it would be a kluugey setup.
    Assuming the TS requires 12vDC, then I think it would be easier and more reliable to power the TS from the M4 instead.
    How about the Wiki?
    Sep 2009
    Darque-
    I take no offense, but why would it be kludgy? I'd think an independent regulated PS might be more useful in that it sharing the total system load would save the M4 from peaking (remember I am loading it up- though not the 12v rail too much).
    Its just a thought cause PICO is extra at this point.
    Keep em coming-
    Larz
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Most likely your screen only draws 1amp, which is barely anything for your M4. I would say just run it off your M4 for conveniance.
    Elsewhere
    Quote Originally Posted by Larzfromarz View Post
    Darque-
    Keep em coming-
    Larz
    The PicoPSU is ATX-compliant. That means it doesn't provide power until it recognizes current on a certain pin (13, I believe).
    That means you have to short that pin with a ground line with a bit of wire or somesuch for it to provide power.
    That's kluugey in my book.
    Never mind that if the wire or whatever you use to short pin 13 comes disconnected, you suddenly lose power for your screen. And that's not something one would typically look for in the process of troubleshooting.
    I could see that situation being one that causes hair to be yanked out by the roots in sheer frustration.
    Not something I'd want to deal with.
    How about the Wiki?
  1. AMD AM2 CPU Low Wattage
    By ACE in forum General Hardware Discussion
    Last Post: 06-11-2006, 05:13 PM
  2. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
  3. Arrrgh! Can't make up my mind about PS!
    By Pred8tr in forum Power Supplies
    Last Post: 01-27-2003, 12:22 PM
  4. Converting AT PS to ATX PS? How to?
    By Maveric in forum Power Supplies
    Last Post: 08-15-2001, 10:50 AM
  5. Arise ACE-865V dc-dc ps, system wont post, help...
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-17-2000, 03:08 AM
