Results 1 to 7 of 7
Thread: how to flash m2-atx?
    Jan 2005
    does anyone know how to flash a m2-atx I was having issues so I emailed mini-box and the response I got was this file should fix your problem I hope you have the tools to do it.
    yonu
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ive been thinking about this too, mainly to change the startup delay time. Do you think you could send me the source code file that was given for the M2-ATX? I came across a pic programmer, but couldnt find the source file for the M2's chip. If I figure it out, Ill let you know.
    Jan 2005
    here is the fw file they sent me hope it helps
    Attached Files Attached Files
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Try downloading a pic flasher program and see if you can figure out how to get it working (without actually flashing). Then if you decide to flash the pic, you can get a kit like this:
    http://cgi.ebay.ca/Easy-ISP-Microchi...item2555d57a90
    Jan 2005
    ok that works will start messing with it
    was that file what you were looking for?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Yea, that hex file loads into WinPic perfectly. But if there were parameters you wanted to change (such as startup delay, timings, etc...), then you would need some sort of source file I think.
    Jan 2005
    well I took the hex file and the pic down to a instuctor t the local tech college and got them to flash it real quick for me however it now works but the mb on signal stays on instead of pulsing so i guess i will contact mini-box again and see if they will send me a new file
  1. newbie needs help with m2 atx
    By luna123black in forum Newbie
    Last Post: 08-05-2009, 10:54 AM
  2. M2 atx possible problem
    By millsy in forum Power Supplies
    Last Post: 11-25-2007, 09:05 AM
  3. m2 ATX, ground to chassis or battery?
    By Snortonnorton in forum Power Supplies
    Last Post: 07-16-2007, 04:02 PM
  4. M2 ATX "D1" part dead HELP!!!
    By Elifromthevi in forum Power Supplies
    Last Post: 07-05-2007, 05:00 PM
  5. Problem m2 atx and 3.5" hard drive
    By Mitski's Rider in forum Power Supplies
    Last Post: 10-05-2006, 12:52 PM
