plug it in, power it, attach it to your PSU and go
It's turnkey, you don't need to do anything else to it. You might want to add in a shutdown controller or something to automatically turn it on and off, but other than that it's ready to go.
So If i buy one of these what do i have to do to get it working right?
IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
Well I may be interested....you guys say that you have induced noise with your inverters...how much noise? Mine makes tons of noise...turn the stereo up and it gets louder...turn it all the way down and no noise at all????
anyway, will this thing you are possilby doing the group buy on eliminate all noise?
i have an amd 1.4ghz, nesa 7in screen, xbox, cdrw, ide to usb 2.0 converter and usb 2.0 hub.....will all this work with what we might buy?
also, if any of you have the time, read about the problems I am having with my inverter in my car....
here is what i did....I went out to the car and hooked the inverter back up in the trunk....turned it on and there was no noise as usual...then i hooked the extension cord up (runs up front where I can hook up a power supply)...if not hooked to the power supply, no noise...hook to power supply....screaming noise with volume up, no noise at all with volume down......so i unhook the extension cord from the power supply.....no noise....but as i moved the extension cord around inside the car...it would pick up noise...the closer i got to the stereo, the louder the noise got.....move it away from the stereo....no noise...hook it back to the powerstrip where the xbox and other things are connected......NOISE
so up to a point, there is no noise produced by the inverter...and then when i get closer to the powerstrip where my stuff is plugged in...lots of noise.........what should i do now? try and run the wires a different way???
if the extension cord is not plugged into the powerstrip with all the goodies...there is no noise....if I move the extension cord more toward the center of the car, i begin to pick up slight signal noise....
i tired bypassing the power strip and plugging straight into the xbox....but the loud noise is back.......remember, I do not have any of the components turned on while I am doing this....
any ideas?
Almost certainly yes.Originally posted by johnny010
Well the 1.4GHz can draw 65W maximum (13A on the 5V rail, already 3A over the maximum) which means if you want to use it you'll have to underclock it (do you really need 1.4GHz in your car?) Running at 933 (bus at 66 instead of 100) it'll only draw a maximum of 8.7A, which should be fine. The screen can run easily off of the +12V regulated from the PSU, do you plan on burning CDs while in your car? (Do you really need a CDRW in your car?) IDE to USB2.0 converter (?? using what?)... However the x-box is a no-go, it'll draw a lot of power (max 36W for the processor alone, probably another 18W for the graphics card, so you're looking at ~5-6A at 12V). You'll need to build a special converter for that, or I don't know if you can hack it to run directly off the car's power. However I don't think it matters which DC-DC PSU you get, you're gonna have a hard time running an x-box off of it.Originally posted by johnny010
i have an amd 1.4ghz, nesa 7in screen, xbox, cdrw, ide to usb 2.0 converter and usb 2.0 hub.....will all this work?
Everything makes sense up to the point where you say that nothing is turned on when this phenomenon is happening. 120VAC at pseudo 60Hz will cause a brutal hum in your audio system if any wires carrying current runs next to a wire leading into your radio, however there should be no noise if the cable is not carrying current. You say that if you plug the extension cable into the inverter without anything plugged into it, there is no noise, but as soon as you plug something into the extension cable there is noise? This sounds very very strange because, again, if there is no current draw then nothing should happen. If, however, this only happens when there is current draw then it makes sense.Originally posted by johnny010
What type of inverter do you have? Try to run power cables (ALL power cables, including power TO the inverter) away from any speaker wires or radio wires). You can try to buy a different inverter, see if that solves your problem, or try to buy a radio noise filter. Additionally you can try to put noise inhibitors on all power wires running into your inverter and radio, and how do you have your inverter plugged in? Make sure that you are using thick wires, and that the ground wire for the inverter is close to the inverter itself and is in the trunk, securely attached to the vechicle chassis. Do you have amplifiers in the trunk as well?
okay, thanks for responding...
here we go...
1) i have the ide to usb 2.0 converter so i can burn cd's..the computer is in the trunk and the cdrw is in the glove box...thus the need for the converter
2) the inverter is grounded in the trunk, close to the unit. i tried grounding both the stereo and the inverter in the same place but no luck. i tried different inverters but the same LOUD NOISE was still produced.
3) the only thing I can think of when I plug the extension cord to the power supply is that the power supply is turned on....but this doesn't makes sense b/c when I bypass the strip, and plug in the xbox directly, without turning it on, i still get the same loud noise.
4) when the extension cord is plugged into the inverter (in the trunk)...and run along the driver's side....without plugging into the power strip, there is no noise...however, if I move the extension cord more toward the center of the car (stereo is in AUX mode)...i begin to pick up a slight buzz noise....if I move the extension cord toward the speaker wires...no noise...if i move it toward the stereo face plate, no noise (the face plate is mounted away from the brain of the cd player, which is mounted in the glove box...).....if I move the extension cord toward the stereo, noise gets louder.....move it toward the xbox (mounted behind stereo, under glove box) , slight noise but not much.
5) the power/ground wires are no where near the power strip, but when i plug that sucker in...LOUD NOISE
6) the power wires for the xbox aren't near the power wires/speaker wires of the stereo
7) i do have an amp in the trunk but the power is unhooked and the rca's are disconected from both the back of the stereo and the amp.
here is what anohter member said i could try with the xbox....see what you think....
---"I am currently using a DC-DC power supply that comes with a Mini-Itx Case that I bought. I think your main problem is the inverter. If you read thru some posts on MP3car, you will find that most of us that are serious about sound quality will use some sort of DC-DC power supply to run everything. What I would do, for the X-Box, is find out if there is a automotive adapter (or just see what the output is of the ac adapter) and use that. it is probably 7.5 or 9 volts DC that it needs and you should be able to find a regulator like that pretty easy. "
thank you again for all your help Telex. Please, if you have more questions, ask away.
JMM
Why do you need to burn CDs in your car??Originally posted by johnny010
What gauge wires are you using? Can you elaborate a little more on what "LOUD NOISE" means? Are we talking about a 60Hz hum, or ... ?Originally posted by johnny010
So essentially you get the same loud noise regardless of if the extension cable is plugged in or not?Originally posted by johnny010
So you have nothing plugged into the inverter except for an extension cord, and if you move this extension cord (with nothing plugged into the inverter except for this cord) towards the head unit, it starts making a buzzing noise?Originally posted by johnny010
There will be no "car adapter" for the x-box since (a) it was never designed to be run in a car and (b) it takes a direct 120VAC and has an internal power supply. What you can do, however, is remove the internal power supply (keep in mind that the x-box is just a PIII/733) and put in a normal ATX DC-DC PSU. I don't think that a sproggy would do it because the x-box will be intensive on the graphics, which is run off of the 3.3V rail, most likely needing > 10A to run, plus an additional 35W on the 5V rail for the CPU, plus the USB controllers, hard drive, etc. An Opus *might* be able to power this, I don't know."I am currently using a DC-DC power supply that comes with a Mini-Itx Case that I bought. I think your main problem is the inverter. If you read thru some posts on MP3car, you will find that most of us that are serious about sound quality will use some sort of DC-DC power supply to run everything. What I would do, for the X-Box, is find out if there is a automotive adapter (or just see what the output is of the ac adapter) and use that. it is probably 7.5 or 9 volts DC that it needs and you should be able to find a regulator like that pretty easy. "
No problem, but this is quite a doozy.Originally posted by johnny010
Telex...once again thank you for your help....here is what i did to fix the problem![]()
I knew that when everything was hooked up to the inverter AND the stereo was in AUX mode, there was like a super loud noise...not just a hum........but when everything was hooked up and the stereo was in STEREO mode...there was no induced noise through the speakers.....
so what did I do? you guess it....bought an FM modulator for $40.
sounds great...no noise at all...clean and crisp.
what do you think? this was an easy solution and cheaper than buying a dc to dc converter....
Also, I want to be able to burn cd-r's b/c every time i go somewhere I can have friends upload their cd's onto my computer and i can burn them cds from the other songs i have on the hdd.....eventually, i will have a ton of songs from all my friends and they will get something out of it too....sounded cool to me!
no on to the next problem...please view this link...go toward the end and you will see my last few posts where i have pictures of the eject/power board for the xbox...i am trying to extend the buttons with momentary switches (off position)
here is the link
http://www.bimmerforums.com/forum/sh...threadid=90140
Damn DDT... you building them for a living now? Or is it some hot piece of *** that your trying to get into?
ok great, is there anyone else that wants one?
It's looking like I'm actually not going to be getting one, seeing as how I have a working sproggy now and enough parts to add the extra power to it that I need (not to mention not a lot of money).
That's OK though, because as I pointed out we'd need someone in the US to do the bulk order, otherwise the cost goes up by like 10% because of stupid Canadian import taxes.
I've also got the shutdown controller specs and am working to add that into the sproggy design.. nice because you can re-use a few of the components already in the PSU so it'll be cheaper than an external solution.
