Results 1 to 7 of 7
Thread: Determine Fuse Rating
    Aug 2009
    Houston, TX
    Folks, I have a Carnetix P1900. I'll be running a Mac Mini and a Lilliput EBY701. The Mini power adapter runs at 120W @ 18.5V and the EBY701 needs less than 10W @ 12V.
    If my calcs are correct that is about 7.32 amps. That seems very small compared to what I was imagining it would be.
    Can someone confirm that this is correct? I am trying to determine the correct fuse and wire size running from the battery to my P1900 and from the P1900 to the Mac Mini and Lilliput.
    Thanks.
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    120W = 10Amps @ 12V
    so 10A fuse is ok, or 15A if you never want it to blow.
    MacMini in an Alfa? - Why not!
    Elsewhere
    The fuse is to protect the wire.
    You want the fuse to fall between the maximum power draw of your equipment and the maximum power the cable can handle.
    Your amperage calculation is spot on, and the recommendation of a 10A or 15A fuse is, as well.
    How about the Wiki?
    Aug 2009
    Houston, TX
    Quote Originally Posted by pulsarsimon View Post
    120W = 10Amps @ 12V
    Maybe I'm thinking of this wrong, but the wattages I described above come after the P1900. Therefore the amps being pulled from the battery should be the sum of the amps being pulled from the PSU.
    Code:
    Mac Mini
    120W @ 18.5V = 6.5Amps
    Lilliput EBY-701
    10W @ 12V = 0.83Amps
    Total Amp Draw
    6.5Amps + 0.83Amps = 7.33Amps
    The Total Amp Draw from all of the equipment connected to the P1900 should also equal that pulled from the battery (+ inefficiency of equipment, but not counting that here).
    Maybe that gets me, by coincidence, to the same fuse you described (10Amp).
    Jul 2009
    Quote Originally Posted by brownaa82 View Post
    Correct me if I'm wrong, but you fuse what the car supplies (12V)
    '93 Toyota Celica - First Car PC install
    Current System Specs:
    ZOTAC GF8200-C-E AM2+ GF8200
    AMD Athlon 64 X2 3800+
    1 GB DDR2 667
    LITE-ON DL-8ATS Slot-Load
    750 GB Seagate SATA HDD
    250W PSU
    19" Hyundai Monitor
    Aug 2009
    Houston, TX
    Quote Originally Posted by cjrokke View Post
    Definitely. I'm trying to figure out if you add up the amps being drawn by each piece of equipment, then get the fuse. Presumably the fuse would be installed as close to the (-) terminal on the battery as possible.
    Feb 2007
    Taylorsville, UT
    You will need to add something like 20% to account for the inefficiencies.
    The mac mini psu OUTPUTS 120W but it probably DRAWS closer to 150.
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
  1. Igniton Fuse Keeps Blowing
    By TeamRSX in forum Power Supplies
    Last Post: 05-06-2008, 11:02 PM
  2. How to pick the right fuse rating.
    By MastaShake in forum Newbie
    Last Post: 08-10-2007, 12:00 AM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. What is the Rating of a Fuse??
    By Boostz21 in forum General Hardware Discussion
    Last Post: 08-10-2004, 12:37 PM
  5. ITPS fuse rating
    By delussional77 in forum General Hardware Discussion
    Last Post: 05-29-2004, 12:34 PM
Tags for this Thread
